Rear sway bar...Is it worth it?
Old 10-08-2015, 08:06 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Default Rear sway bar...Is it worth it?
Since I've been showering the love on the Fastback here as of late, what with the addition of an 8" Trac-Loc and AC, I've been kicking around the idea of upgrading the sway bars.
I've decided to go with a 1" front sway bar to replace the iddybiddy factory piece but I am undecided about a rear sway bar. I only drive her on the street, no autocross or anything like that so would I benefit at all from the addition of a rear sway bar?
Thoughts & suggestions are appreciated.
fastbackford351 is offline
Old 10-08-2015, 11:24 AM
69mach1377
69mach1377's Avatar
I added a 3/4" because the torque of the engine caused the car to move about wildly...
69mach1377 is offline
Old 10-08-2015, 04:08 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Do you have limited slip or an open diff? How is your front suspension stiff/loose? On a limited slip a rear sway bar will help reduce over steering or at least be able to do it in a more predictable manner provided you don't over stiffen the rear in comparison to the front. If you have an open diff you'll make over steer worse regardless.
Derf00 is offline
Old 10-08-2015, 07:18 PM
fastbackford351
Foghorn Leghorn
It's an 8" traction lock.
The front end is rack & pinion steering, fresh factory upper & lower control arms with a 1" Shelby drop on the uppers & koni shocks.
Old 10-09-2015, 01:54 PM
guitarman376
guitarman376's Avatar
Sway bars are a very helpful suspension tuning tool, but whether or not your car needs one is TBD. I say go without a rear bar for a while, and find a safe place to push the car to its grip limit and see how it reacts. My car WAS understeering, but I changed the springs and will go for different alignment settings (haven't done this yet) and will see if I would benefit from a rear bar. I have an open diff so keeping the car understeering might be beneficial. My plan is to get the car more sorted once its on the road. Just welded in the outer shock tower plates today...
guitarman376 is offline
Old 10-10-2015, 02:08 AM
barnett468
barnett468's Avatar
No.
barnett468 is offline
Old 10-14-2015, 05:11 PM
groho
groho's Avatar
You'll find the 1" front will be sufficient for your needs. what I noticed once I upgrade the front sway bar, was the amount of body flex and suspension movement there is in these cars. I've got a very similar set up to you in my 66 and I've got a 3/4" rear bar that's still in the box, 2 years later, never found a need to put it in. My suggestion, try subframe connectors before the rear bar.
groho is offline
Old 10-14-2015, 06:32 PM
fastbackford351
Foghorn Leghorn
Subframe connectors were the first mod I put on the car when I got it.
Old 10-23-2015, 02:18 AM
67mustang302
67mustang302's Avatar
Race Car Vehicle Dynamics (R146) (Premiere Series): William F. Milliken, Douglas L. Milliken: 9781560915263: Amazon.com: Books Race Car Vehicle Dynamics (R146) (Premiere Series): William F. Milliken, Douglas L. Milliken: 9781560915263: Amazon.com: Books
67mustang302 is offline
Old 10-23-2015, 06:23 AM
fastbackford351
Foghorn Leghorn
Looks like a good read. Santa Clause is coming soon, maybe I'll find it in my stocking.
Diode Dynamics
50
04-13-2022 01:49 PM
68SCode4speed
10-29-2015 07:04 AM
Sabrina Radomski
10-09-2015 05:53 AM
seanwillis0826
10-07-2015 03:46 PM
winner99
10-01-2015 10:52 AM
Quick Reply: Rear sway bar...Is it worth it?
