Tranny not shifting out of 1st
Old 11-16-2015, 03:34 PM
snafu7x7
snafu7x7's Avatar
Default Tranny not shifting out of 1st
It's an automatic. If I manually put it in L1 or L2 it works as expected but in D it does not.
This just happened the other day, drove to a restaurant, everything was fine, on the way back the car wouldn't shift out of 1st. I let it sit overnight and same thing this morning. What might be going on here? The tranny was rebuilt just 3-4 years ago (probably has 3-4k on it tops).
snafu7x7 is offline
Old 11-17-2015, 11:48 PM
Mustangdemon67
Mustangdemon67's Avatar
There's a vacuum line that runs from the intake manifold (or carb) down to the passanger side of the transmission. Make sure that's connected and that the rubber is good and not cracked / ripped.
Mustangdemon67 is offline
Old 11-18-2015, 08:49 AM
snafu7x7
snafu7x7's Avatar
I actually took it into the transmission shop yesterday and got it fixed. It was exactly what you described MustangDemon. There's a hose that comes off a vacuum port on the carb and connects to the transmission...no vacuum, no shifty so that was the problem, the hose has a bracket that had come off and the hose had ruptured. Easy fix and I'm back in business.
snafu7x7 is offline
BeatnikFink
10-01-2015 08:00 PM
skysurf
04-25-2011 05:10 AM
Mike521
01-08-2007 08:34 AM
imyy4u
11-29-2006 12:34 PM
ronchap200027
03-15-2006 01:52 PM
Quick Reply: Tranny not shifting out of 1st
