Carb or return spring or linkage?
I've got a 66 coupe 6 cylinder, when I am accelerating
then push the clutch in or put it in neutral, it like idles really high. Then if I put my foot behind the gas pedal and pull back, it calms down.
Could this just be the return spring? Or maybe the pedal assembly linkage? Or a carburetor problem.
Also, I want to get a new carburetor but do not low which one is good to get with the 6 cylinder and I do not know which one I currently have. I assume it's the normal autolite one but I'm not positive.
it is sticky linkage or weak return spring or worn throttle shaft
if you still have he orig distributor you need a 68 or later if you use a non stock carb otherwise you will not have any ignition advance.
I believe it's the original distributer but not sure the cap looks brand new. Maybe sone one just replaced the cap lol. So what do you mean I'll need a 68 or later
try moving the linkage by hand to see if it returns all the way. Also where is your return spring attached? There are a couple different places it can hook, which can give different throttle feel. Mine is hooked to the end of the intake log, which makes it have a strong return.
I am still planning on getting a get carb though.
NorthAmericanTuning
09-23-2016 09:15 AM
NorthAmericanTuning
11-17-2015 08:55 AM
