Header Clearance on Mustang II suspension
Old 12-16-2015, 09:18 AM
65mechanic
65mechanic's Avatar
Default Header Clearance on Mustang II suspension
Hey guys. Trying to deal with some header clearance on my 1965 Coupe. I've purchased the Flowtech #1240FLT long tubes for a 79-93 mustang (Foxbody). Foxbody year headers are what I was told to use with my front suspension. So I get these set in and I already see some clearance issues with the steering linkage, brake lines, and they're setting against the frame. Yes, I'm aware I can heat these up and make them fit, bend the brake lines away, etc. Just curious if all foxbody long tubes are like this? I wasn't thinking they'd have the steering actually go through the header. I'm running a hydraulic clutch, so I'm not picky with what headers I do go with, I'm just curious if there's a set that fit better for my application. Note: I did set the motor 1/2" closer to the passenger side for header clearance, as I was informed I was 'allowed' to do. Here's some pictures of the situation. Thanks guys.
Attached Thumbnails Header Clearance on Mustang II suspension-img_8306-3-.jpg   Header Clearance on Mustang II suspension-img_8345-1-.jpg
65mechanic is offline
Old 12-18-2015, 08:47 AM
65mechanic
65mechanic's Avatar
Bump, anyone have an idea? Moderator, maybe this question needs to go to foxbody tech? Idk..
Old 12-18-2015, 11:25 AM
69mach1377
69mach1377's Avatar
Yeah, I think these are not the droids you are looking for...
69mach1377 is offline
Old 12-26-2015, 06:05 PM
MustangsToFear
MustangsToFear's Avatar
Fox body BBK clears fine.
MustangsToFear is offline
evo8
12-04-2015 08:30 AM
LordRipberger
10-17-2015 10:18 AM
Buckodavis
10-12-2015 06:40 AM
mnccnm
10-11-2015 04:04 PM
seanwillis0826
10-07-2015 03:46 PM
Quick Reply: Header Clearance on Mustang II suspension
