Question about cam
#31
I just thought of something that could be causing the problems but wanted to check and see if it is an issue. When i installed the timing chain i made sure to line up the marks on the cam and the crank so the dots are inline. What i did not double check is that the crank was on TDC on the compression stroke, just that it was TDC. Is it possible that i installed it on overlap and that is causing the issues? Would the engine still run like that, but just be very underpowered? Is there a way to check this without taking off the timing cover?
Thanks,
Tim
Thanks,
Tim
#32
Thanks,
Tim
Thanks,
Tim
it might be best if you take it to a mustang shop and have them drive it so they can tell you if its running properly or not, because unfortunately, there is no way we can tell you that from behind a computer.
Flade99
11-06-2015 08:59 PM
