Installed Ron Morris Motor Mounts
It's not the pressure that gets the plastic lines,since the oil pressure never goes above 120 psig, but the heat. Just make sure it is not touching a hot manifold. PVC is good to ~165°F, Nylon to~ 200°F, High pressure Polyethylene (HDPE) for compression fittings to ~180°F and Teflon (PTFE) for compression fittings to ~500°F. PTFE is also flame retardant, but expensive.
JUSTA2V_04
11-25-2015 05:40 PM
