any difference in 289 vs. 302 heads
Old 02-15-2016, 11:19 PM
MonsterBilly
MonsterBilly's Avatar
Default any difference in 289 vs. 302 heads
I have a set of 289 h a ads from my mustang. They have been ported and have screw in studs with guide plates and a recent valve job with some good solid springs.
I picked up a 75 bronco with a 302 which is bone stock. It has a 2bl carb. I also have an extra 60pcfm edelbrock carb and a brand new intake. So I was thinking, if I'm gonna put the carb and I take in, why not put on the 289 heads that have been worked over?
Please gimme your thoughts
MonsterBilly is offline
Old 02-16-2016, 03:49 PM
groho
groho's Avatar
does your 75 heads have a air injection ports? that was pretty standard back the early 70's.
groho is offline
Old 02-16-2016, 06:06 PM
barnett468
barnett468's Avatar
The 289 heads should have smaller combustion chambers of 54 cc . You will need premium gas and will need to curve the distributor for optimum timing.
If the 302 has flat top pistons, you should check the deck height of the pistons and use a thinner head gasket if necessary to get the quench/squish clearance between .043" and .034".
barnett468 is offline
Old 02-16-2016, 09:17 PM
MonsterBilly
I'm not sure if they have air ports. It did have a smog pump which has since been removed if that is any in inclination
I have not taken the intake and heads off of the 75 yet. It runs fine I just have the stuff laying around so I thought what the hell. I also have a new set of roller rockers as well so I may as well get a cam.
Old 02-17-2016, 06:36 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
If you have a set of bone stock 75 302 heads vs. some worked over 289 heads, I'd find it hard to believe that the 289 heads wouldn't be a better setup all the way around. By 75 Ford heads were so pitifully choked back, especially on the exhaust ports that they were a bad joke for making power.
I'm usually a guy who subscribes to the "if it ain't broke don't fix it" mantra but in this case, I think I'd make that swap.
fastbackford351 is offline
Old 02-19-2016, 02:13 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
sell all those heads and get some heads from a 96-97.5 explorer...then youll have gt40 heads that outflow all stock 289/302/351w heads even the c9 and d0 351w heads
rmodel65 is offline
Old 02-20-2016, 03:03 PM
crazyJak
crazyJak's Avatar
Hello, new member logging on for first time. I remember putting 351W heads on a 302, after having them milled down to restore the comp ratio. The 351 had bigger valves. You had to use a certain head gasket to allow water flow. Anyone know if this would work on 289s?
crazyJak is offline
Old 02-21-2016, 02:27 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yes..but gt40 heads from a 96-97.5 ford explorer outflow the 351w heads from 1969-1970 and already have hardened valve seats. and you can find them all day long for 100$ or less at the local pull a part place..
rmodel65 is offline
Old 02-21-2016, 04:18 PM
69mach1377
69mach1377's Avatar
^Don't those require special exhaust manifolds or headers?
69mach1377 is offline
Old 02-21-2016, 05:07 PM
barnett468
barnett468's Avatar
not the gt40's . the gt40p heads sometimes require short spark plugs and ceramic boots, but most headers will fit them.
Quick Reply: any difference in 289 vs. 302 heads
