1969 Mach 1 Build - Heather
Old 03-26-2016, 09:22 PM
  #41
69MACH1BUILD
69MACH1BUILD's Avatar
Originally Posted by barnett468
what trouble are you having with the shock bracket?
I used locking nuts which gave me some troubles. Switched those out and had no problems!
69MACH1BUILD is offline
Old 03-27-2016, 03:12 PM
  #42
69MACH1BUILD
If I want to change this to manual steering is it ok to remove the power steering cylinder?
Power steering cylinder.
Old 03-27-2016, 09:42 PM
  #43
barnett468
barnett468's Avatar
yes, the cylinder must be removed for the conversion.
barnett468 is offline
Old 03-29-2016, 12:40 PM
  #44
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
I see refurbished factory power steering setups going for upwards of 5 or 600 on Ebay. If it wouldn't take too much to bring yours back up to par you might stand to make a few bucks.
fastbackford351 is offline
Old 03-31-2016, 12:56 PM
  #45
racer_dave
racer_dave's Avatar
if you aren't going to correct/stock look into the servo style power steering we use on the racecars. uses a small pump from a cavalier (I think), remote tank and an aluminum bracket. Speedway, jegs, summit all carry them for about $300 you'll have all new stuff.
racer_dave is offline
Old 04-10-2016, 01:04 PM
  #46
ruger
ruger's Avatar
You will need 70' tie rod ends and wheel bearings. The 70's tie rods are a few thousands bigger in diameter along with the spindle where the bearings ride. 69" tie rod ends will not fit into the steering arm. 69' bearing will not fit the spindle.
ruger is offline
