Which Horn Button to Use
Hey guys,
Just picked up my next Mustang project a '67 coupe. It's got an aftermarket wood steering wheel, sans center cap. I've looked all over the wheel and cannot find a manufacturer name. Anyone have a suggestion on a center cap/horn button to use? I'm not concerned about anything factory correct, just want to get a horn button on there.
Thanks!
Keith
Thanks!
Keith
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
I am almost positive that is an old Grant aftermarket. It's a dead nuts knockoff of the one I use to sport.
http://www.cjponyparts.com/grant-ste...-1969/p/STWG2/
You need to be careful with the horn button. Because the button has 12 volts on one side and goes to the horn on the other, there is a possibility of grounding the 12 volts . The horn and stoplight switch power is fed from the light switch which has an internal circuit breaker. There are special instructions concerning modifying a spring clip, which if not modified, could contact the wheel housing causing a short.
Do you guys have a particular wheel you prefer? I'm not doing an original restoration so I'm not worried about keeping things original but I have heard a lot of people saying they have trouble with horn buttons on the 'Stangs
jesse1125
01-15-2016 10:56 AM
