widest rear tire ?
Old 03-14-2016, 08:15 AM
Mustangs of Illinois
Mustangs of Illinois's Avatar
Default widest rear tire ?
I will be changing my tires and wheels.
I will be going to a Cragar S/S 15x8 in the rears. What is the widest tire that will fit with no clearance problems ? Will a 255/60R15 fit in the rear okay ?
I currently have 245/40R19 under the rears. But they will rub sometimes.
Mustangs of Illinois is offline
Old 03-14-2016, 09:25 AM
69mach1377
69mach1377's Avatar
Take a lot measurements to get the proper back spacing on the new wheels. You might have more room towards the leaf springs and the bumper tab can be bent up.
69mach1377 is offline
Old 03-14-2016, 09:51 AM
I bent up the tab when I installed the 245/45R19 tires and wheels
Old 03-14-2016, 10:57 AM
69mach1377
69mach1377's Avatar
Mod the fender for the outside of the tires? Where is the rub happening?
Old 03-14-2016, 09:20 PM
Just a little to wide. I have rolled the lips, but it is still to close. The fronts are just too close for comfort for me. It does look amazing. But I want something closer to what I had on my old 67. It had G50-15s on it in the back...
Old 03-15-2016, 09:17 AM
69mach1377
69mach1377's Avatar
Did you check dodgestangs sticky at the top here?
I think you might have found the max.
I have 285s now but could probably squeeze 295s on my 69.
Old 03-15-2016, 07:22 PM
Actually I did check. My car is the last one in the post at this time ?
Old 03-20-2016, 09:51 AM
Well I have my Cragar S/S rims and tires ordered.
Going with 7" in front and 8" in rear.
Tires will be 245/60R15 Goodrich radial TA in rear
Front tires will be 215/60R15 or 215/65R15 Goodrich radial TA depending on if they have the 60 series in stock.
Will post photos after I get them on. Plan on putting my Thumper cam in this coming weekend, already have the electric vacuum pump and canister installed.
BKamp613
04-15-2016 03:39 PM
mustangman02232
03-13-2016 01:28 PM
Offendant
03-11-2016 10:03 AM
dmastinsc
03-10-2016 01:39 PM
noahwoodcock
03-07-2016 02:49 PM
Quick Reply: widest rear tire ?
