Trouble With Heater Cables
Old 05-07-2016, 09:26 PM
carsofchaos
carsofchaos's Avatar
Default Trouble With Heater Cables
Hi All,
Having an annoying problem with the heater cables on my 67. Specifically the cable that attaches to the DEF level. As soon as I slide the DEF level up or down, the cable pops off the post. The other two cables (TEMP, HEAT) don't have this problem. These are brand new cables. I know at the other end of the cables (on the heater box) there are little caps that hold the cables onto the posts. No problems there. But there doesn't seem to be anything I've seen that's supposed to hold the DEF cable onto it's post. Would love to get my dash put back together but this is holding me up. Any thoughts?
Thanks
carsofchaos is offline
Old 05-09-2016, 06:01 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
How are the other two cables held in place?
fastbackford351 is offline
Old 05-09-2016, 10:43 AM
carsofchaos
They are just hooked onto the back of the sliders, nothing is holding them on but they don't fall off. Only the DEF cable falls off.
Old 05-09-2016, 02:35 PM
fastbackford351
Foghorn Leghorn
Sounds like it's kinked or that there is enough of a bend to put it into a bind.
Old 05-23-2016, 09:48 AM
70XR7Tom
70XR7Tom's Avatar
My '70 has clips on the cable connections. They are like small washers with spring teeth on the inside diameter. They are a nuisance to remove and frequently damaged or lost when removing.
70XR7Tom is offline
Old 05-23-2016, 10:16 AM
carsofchaos
I'll say! My cable ended up being twisted, got a new replacement from CJ no questions asked, installed without issue.
Old 05-23-2016, 10:46 AM
70XR7Tom
70XR7Tom's Avatar
Sound's like you've got it fixed. If you want to add the retainers they are available. Push on Retainers for 3/16" shafts and posts. All of the '70 ones are 3/16" I'm sure they are available from many of the Mustang sources but also West Coast Classic Cougars part no. 11998 for all $0.25 each. I'm currently rebuilding my whole heater A/C box so I've become familiar with many of these parts.
70XR7Tom is offline
65Lucille
05-09-2016 08:49 PM
iraqandroll
05-05-2016 04:57 PM
axyun
05-03-2016 04:53 PM
Luisfercaz2
05-02-2016 07:39 AM
Luisfercaz2
05-01-2016 10:20 PM
Quick Reply: Trouble With Heater Cables
