Vibration
when did it start.
if you rev the engine in park and it vibrates, it is likely the engine or torque converter or bent flex plate or broken trans or motor mount.
if it only vibrates while you are driving, bad u joints, bent driveshaft or yoke, bent rim bubble in tire, bad driveline angles.
i had a bad vibration on the highway for over 4 years. I could not figure out what it was. It ended up being the pinion shaft in the rear end. it gave out on me one day, i had it rebuilt and now there is no vibration.
just jeep looking. use all the ideas from above
rooneyeb
06-12-2016 10:09 PM
Keenan95
05-19-2016 10:25 AM
Sgkukov
04-29-2016 09:50 AM
