Engine not firing
Engine not firing
Car: New 302 crate motor with all new accessories. (starter, alternator, MSD pro billet distributor, etc) 850 miles on it.
Problem: wont fire, cranks perfectly. went out last night drove fine, ran fine, a few stops here and there, started fine.
Problem is it will not start now? (following morning) like I said, its turning over just fine. just no spark?
the only issue I can think of is the shifter for transmission is really F***ed..
it is not stable. hard to shift into gear, not stiff, it's really loose.
could this cause a problem? transmission cause engine not to start?
if not any help would be appreciated.
sorry if not posted in proper thread.
when you installed the distributor, did you remove and or bypass the resistor. Unless im mistaken that dizzy requires 12v of power. If you use the stock wire, it may only be getting 9v.
just a thought. maybe try to run a jumper wire off of the battery side of the solenoid directly to the dizzy and see if it fires..
otherwise, it sounds like a ignition switch issue
Thanks for the input guys,
GUN JAM: No A6 box required, everything is in distributor.
Monster billy: has 12V
Initially car would crank,(yesterday morning). tried yesterday after work. not cranking at all.
checked everything through electrical system. everything is in good working order.
or seems to be..
As stated in initial post: transmission shifter is wonky. (C4 trans), sometimes really hard to shift into gear, sometimes works fine. I am now leaning towards the Neutral safety switch.
the symptoms match a bad switch.
Looks like my next upgrade: AOD-E
or seems to be..
So if you pull the boot off the coil and place a grounded object like a wrench about 1" above the coil and crank it over will spark jump from the coil to the wrench? Its is large and bright?
Bad coils can provide weak and intermittent spark as they die.
I would check for that next as its easy and cheap and a good next step in the process of elimination
it wouldnt crank if it was a neutral switch. check basics, is the carb getting fuel? is there strong spark? is the distributor locked down, or did it turn on you? and remember........just because the parts are new, doesnt mean the parts are good.
