ford tach hook up - MustangForums.com
Old 02-22-2017, 08:55 AM   #1
barrylink
Default ford tach hook up
i replaced the points system and put in a ford duraspark 11 , now my tach is messed up so i wondered if anyone has the proper tach connection Schematic for this configuration?
barrylink is offline   Reply With Quote
Old 02-22-2017, 08:59 AM   #2
barrylink
this is the wiring schematic, now what led do i use to go to the tach?
Old 02-22-2017, 05:32 PM   #3
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Oof. What kind of tachometer is it?
Ford wires their tach as part of the circuit instead of reading across it like Brand X and aftermarket tachs. I also was running the DSII setup in my 67 and I wound up running new wires separately from the factory harness. That schematic you have there isn't gonna cut it as far as wiring a classic factory tach goes.
Here is a link
fastbackford351 is offline   Reply With Quote
Old 02-23-2017, 09:15 AM   #4
barrylink
I am running a Factory tach, so mi need to know where i need to run the lead that usually goes to the coil. The ground is no trouble but the other lead is my concern as I'm not sure where it must go to? on the duraspark 11. the factory tach only has the two leads..
Old 02-24-2017, 09:37 AM   #5
fastbackford351
Foghorn Leghorn
I sold the fastback so I can't check it for absolute certainty but looking at the schematic I posted it looks like one side goes to the negative side of the coil and the other goes to the distributor.
Old 03-19-2017, 08:00 AM   #6
barrylink
I found out I have to use a adapter to use factory tach, thanks to a guy that rebuilds them to work with msd ignition...
