Rims
Rims
I agree the styled steel wheels are very nice. I am using them on my 67. 2 questions will 15' wheels leave enough fender clearance up front and if you have disc brakes you may have to grind the calipers a bit. you wont have to grind much though well worth the effort.</P>
Quig</P>
Rims
Back in 79 I had 15' aluminum slots, the front tires rubbed the fenders. My ole man painted the car while I was in basic training and would'nt let me even move the car until I put different wheels on it. The 14' wheels with 215 70 14 tires look good, handle ok and fit.</P>
Quig</P>
Rims
as long as you have similar backspacing, height and width on the tires, what wheel size you have doesn't really make a difference, if I wasn't so tired I'd do some calculations and give you some tire sizes that would fit fine with 15" wheels</P>
for reference, our mustang works fine with it's 14" wheels, and 235 60 14's, which are just over 24" tall and around 9" wide, not sure on the backspacing though</P>
I've been a fan of the cragar style 5 spoke wheels for quite a while...</P>
Rims
Upsizing always improves looks IMO. If you currently have 14's w/ say (for example) 225/60/R14's thatwouldgive you anoverall height (rim & tire)of ~24.6". </P>
If you upsize your rim to 15" you have to adjust your tire aspect ratio (the 60 in 225/60/R14). So now get a lower profile tire 225/55/R15 will give you an overall height of ~24.7".</P>
So if you wish you cango w/ 16" or even17" (235/40/R17 ~24.4" overall height)wheels as long as you adjust the tire. Not only does upsizing improve looks but it also improves handling.</P>
What is your cuurent TIRE size?, Do you want the same width tire or do you want to go a bit wider?</P>
