clutch pedal assembly
Old 12-06-2005, 09:15 PM
351foxstang
351foxstang's Avatar
Default clutch pedal assembly
hi guys,
is it feasable for me to fabricate some type of system to use the pedal assembly out of a newer mustang in my 67' when converting to manual transmission?
i figure as long as a i get the brake pedal in the correct spot to line up with the pushrod of the master cylinder it would work with a non-hydraulic clutch set up... if i can figure out how to do it i will probably switch the gas pedal as well. mine seems to rest up against the trans tunnel a bit too much.
thanks for your help,
carl
351foxstang is offline
Thunderball
15
11-22-2015 11:49 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: clutch pedal assembly
