convert auto to stick
has anyone out there swapped a c-4 for a top loader. i Know you can do it witha five speed but can't find anything on what needs to be done like they tell you in a t-5 swap. Picking the top loader is practicle because i can get a rebuild on for 650 bucks and getting the other parts are easyout ofrecked mustangs any help is appriciated</P>
I would like to know too. My 66 was a stick and someone converted it. If anyone in the Raleigh area would like to convert a stick to auto I'll trade a C4 with 1000 miles on it for a 3 or preferably a 4 speed.
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNABLE="on">
<T>
<TR height="100%" width="100%" UNABLE="on">
<TD id=HB_Focus_Element vAlign=top width="100%" background=" height=250 UNABLE="off"><FONT size=2>Im looking to do that with my 65, with the 351w. It does seem a bit hard to find the darn parts.</FONT></TD></TR>
<TR hb_tag="1" UNABLE="on">
<TD style="FONT-SIZE: 1pt" height=1 UNABLE="on">
<DIV id=hotbar_promo></DIV></TD></TR></T></TABLE>
<T>
O.K. I just did this on my car(although it's a six, the basic parts list is the same)You will need: The transmission,bellhousing,clutch disc/pressure plate/release bearing,flywheel,crankshaft pilot bearing,equalizer or "Z" bar,clutch pedal,associated springs and release rods,shifter,driveshaft yoke,back-up light switch(if equipped)trans mount and a lot of patience. </P>
I forgot to mention good used 4-speeds are getting harder to find, so good luck with that. Fora T-5 conversion you'll need much of the same stuff, except for the clutch linkage as the T-5 is a cable clutch set-up.</P><edited><editID>bob emmerich</editID><editDate>38023.7792013889</editDate></edited>
BeatnikFink
10-01-2015 08:00 PM
