What to Do?
What to Do?
Well, if it was running fine before, I would say nothing. Just clean the gasket surface and put them back on. If you want to get into some work, replacing the valve seals would be good to do while you're in there.
What to Do?
check your vavle springs,too see if broken?i had i dual spr. that broke i never knew till i changed the gasket like you..the inner was the only one good..<img border="0" src=smileys/smiley3.gif border="0">
