Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-20-2007, 07:01 PM   #1
70coupe
Default original or not
how can i tell by the numbers on my engine block if it was the original one or not?
__________________
1970 mustang coupe, 302, 8 inch rear, ignitor II kit, all new suspension with 1 inch drop springs in the front....more to come soon
70coupe is offline   Reply With Quote
Old 08-20-2007, 07:13 PM   #2
Soaring
I ♥ Acer
Default RE: original or not
If it is a 65 or 66 engine, you can't possibly tell if it was the original engine. If it is a 67 and up there will be a stamped number on the block that corresponds to your VIN. If they are the same, then the engine is the original engine that came with that car.
Soaring is offline   Reply With Quote
Old 08-20-2007, 07:15 PM   #3
66GTKFB
Somewhere near the rear of the block, the last six digets of your VIN is supposed to be stamped. Not having owned a 69 Mustang since 1973, I've never looked. There is the casting number and casting date code located above the starter, which needs to be removed to see all that. Let some of the late classic guys tell you 'the where'.
Jim
66GTKFB is offline   Reply With Quote
Old 08-20-2007, 07:19 PM   #4
70coupe
i have the numbers they are........VIN: 0T01F167662
Engine Number : C90E 6015-C
0E29
__________________
Old 08-20-2007, 07:34 PM   #5
66GTKFB
Does the number you posted from the engine match the number on the left hand side of your windshield and registration?
Jim
6015, block, c90e, c90e6015, c90e6015c, casting, code, engine, ford
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
