Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-19-2007, 02:23 PM   #1
eep4life
Vehicle: 1969, ford, mustang coupe
Default Explorer rear end
hey guys... so hear a lot off people talking about installing a Explorer rear end... what do they mean... a rear diff of of a explorer... you can do that? if so.. what year explorer and what year mustang do they fit on.... and what kind of mods are needed to put it on?
eep4life is offline   Reply With Quote
Old 10-19-2007, 02:25 PM   #2
USMCrebel
Mach I Section Moderator
2003 Ford Mustang
Vehicle: 03 Mach 1
Default RE: Explorer rear end
i am interested in this topic as well, but from what i've gotten is a 94 explorer has a 59.75" rear
__________________
2003 Ox Wht Mach 1 1:814
bone stock
Her name is Melanie
USMCrebel is offline   Reply With Quote
Old 10-19-2007, 02:40 PM   #3
baddog671
Vehicle: 1998 Ford Mustang
90's Ford Explorer rear ends are 8.8" units and have higher gear ratio's than our Mustang's, so, a good upgrade from the 8" most v8's have. 67-70 Mustang rears are 59.25", so 59.75" would still fit. I dunno about the other years, but it would be alittle wide on a 64-66 and alittle short on a 71+. I believe the spring perches need moved/installed to fit though, so some assembly required
__________________
67coupe-351W-new modded suspension-front Granada disc-rear MarkVII disc-new manual steering-braced-31sp 3.25 lok 9" w/ 4pin-sound proofed- reloc. batt
98v6auto DD
"Wether you think you can or can't, you're probably right" -Henry Ford
baddog671 is offline   Reply With Quote
Old 10-19-2007, 02:43 PM   #4
USMCrebel
2003 Ford Mustang
Vehicle: 03 Mach 1
can we get a chrat or something, and if not if you could pm me the info ill throw up a chart for every one.
__________________
bone stock
Her name is Melanie
Old 10-19-2007, 02:48 PM   #5
baddog671
of rear end widths?
I dont have one but I saw one posted on here a little while back
__________________
98v6auto DD
Old 10-19-2007, 02:50 PM   #6
USMCrebel
2003 Ford Mustang
Vehicle: 03 Mach 1
widths gears and years.
__________________
bone stock
Her name is Melanie
Old 10-20-2007, 02:53 AM   #7
eep4life
just bumpin it up to see if theres any one else thats knows about this.. maybe the install requierments.. and such
Old 10-20-2007, 01:29 PM   #8
ky
I lost my avatar and sig for impersonating a mod
1966 Ford Mustang
Vehicle: motard
Send a message via AIM to ky
would it be cheaper to build up a 8 inch rear to withstand 400hp or would it be cheaper to swap out for an explorer rear end? and would i be able to keep the explorer rear end the way it is or would i need to change some guts in it? im interested in this as well
ky is offline   Reply With Quote
Old 10-20-2007, 06:11 PM   #9
y76j2hsk
I put an Explorer rear-end in my 65 restomod (it really is a rotiserie'resto' - not just a 'mod'). It is about 2" wider than a 65-66 8-inch, which is good since I'm using late-model wheels and need the width (no spacers). You have to cut off the spring perches and reweld them outboard (if I remember). I also cut off the sway bar mounting brackets.
The only catch is that the pinion is offset about 3 1/2" to the right. That equates to about 3 deg. at each end on a stock length driveshaft, so it isn't overly 'bent'. The problem is that it hits the tunnel if the car is lowered too much (or so I have read on VMF forums). You can help that by replacing the pinion flange with a yoke (Inland Empire Driveline PY-8.8-1350 if using 1350 u-joints or PY-8.8-1310 if using 1310 u-joints). Yoke is about $55 plus shipping.
I bought a nice 95 Explorer rear-end with 3.73 trac lock from a junk yard for $350. I cleaned it out and checked the backlash and put it back together.I replaced all the brake hardware with new/rebuilt stuff.
I don't have the car on the road yet but I tried 99-04 factory Bullitts with 245/45/17s on it and they fit perfectly. They have about 3/4" space on the backside and fit under the lip on the outside. I used Maier Racing 165# springs.
There are a few posts on VMF (Vintage Mustang Forums). Do a search on explorer.
[IMG]local://upfiles/80027/EF56432FC50E497CB642439DECC8EB63.jpg[/IMG]
[IMG]local://upfiles/80027/959189DD076A4901AC776EC528117A2B.jpg[/IMG]
[IMG]local://upfiles/80027/C143EFBF8D9F469AB1946E56CCE139B5.jpg[/IMG]
[IMG]local://upfiles/80027/58E442E133A64F769A1879C18C052C25.jpg[/IMG]
[IMG]local://upfiles/80027/DD68DECF6A994058B546583F99DC929C.jpg[/IMG]
y76j2hsk is offline   Reply With Quote
Old 10-20-2007, 11:44 PM   #10
mySAVIOReigns
That looks awesome, but I can't figure out what the third picture a pic of? It looks like a cut wheelwell - is that what it is?
__________________
My Website
Yep, I got a blog...
1966 Coupe
200ci, 170ci head, Holley 5200, C4, all brand spankin new
mySAVIOReigns is offline   Reply With Quote
68, 88, diff, end, explorer, ford, gear, mustang, offset, pinion, py, ratio, rear, swap, widths, yoke
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
