New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-12-2007, 01:27 PM   #1
mySAVIOReigns
My Garage
Default Basics of auxiliary fuse box
Does anyone on here know where I can find a good reference (online preferebly) that could teach me some basics about wiring fuse blocks and relays and all that? I've followed a few schematics (such as JamesW's headlight relay mod), and while it is functional, it leaves my bay looking like a rat's nest.
I could hide it all under the metal, but I'm not looking for that exactly. While scrounging the web, I came across this site which is unrelated to Mustangs, but I think it could be applied and would look pretty clean.
Problem is, I don't really know the basics - is there just one wire that goes from the +post of the battery to the fuse block? Also, am I going to have any problems with the battery draining? I plan on redoing the wiring one day (don't we all...) but for now, I'm just looking for a good, safe, reliable wiring fix.
Thanks in advance
edit:
Guess I left off a couple things: As the link shows above, I would like to incorporate the relays into it; I think it will help trememdously with the aesthetics. I plan on running a moderately powerful CD/MP3 player, electric fan, and so on...
__________________
My Website
Yep, I got a blog...
1966 Coupe
200ci, 170ci head, Holley 5200, C4, all brand spankin new
mySAVIOReigns is offline   Reply With Quote
Old 12-12-2007, 02:06 PM   #2
Reverb
My Garage
Default RE: Basics of auxiliary fuse box
This any good to you?
http://www.constructorscarclub.org.n...ringpart1.html
__________________
1970 Mach 1 351C with 4V heads, 4 barrel 650 cfm Holley with an Weiand intake. Will be a 393 soon with JE pistons and Scat crank and 6" H rods - hoping for 8000rpm and maybe a 250 shot of laughing gas.
Reverb is offline   Reply With Quote
Old 12-12-2007, 07:00 PM   #3
JamesW
Moderator
My Garage
http://auto.howstuffworks.com/wfc.htm
__________________
If you're reading this, thank a Teacher.
If you're reading this in English, thank an American Soldier.
JamesW's Website
JamesW is offline   Reply With Quote
Old 12-13-2007, 06:34 AM   #4
kalli
My Garage
Vehicle: 1964, Ford, Mustang
Quote:
ORIGINAL: mySAVIOReigns
Does anyone on here know where I can find a good reference ..... relays and all that?
how a relay works is quite simple. it's nothing but an electronic switch.
if you check on the great diagram:
http://www.midnightdsigns.com/james/...lightRelay.gif
at the lower right you'll find the workings of the Bosch relay ...-150
there are 5 connectors. 1 of them is not used (#87A). So forget about this one.
now what you see in the picture is the relay in the position off.
the battery+ is connected to #30
battery- (ground) is hooked up to #85
your light switch is connected to #86
and the connector at the headlight itself is hooked to #87
So let's check on that:
you have + and - on #30 and #85 (doesn't do anything)
as you can see in the diagram the little switch on port #30 is currently connected to #87A (that means you have 12V+ on this one from #30). But as it's not used, forget about it
Now here comes the interesting bit:
As soon as you flick on your headlight switch, you'll have 12V+ on #86. which will go through the coil in the relay causing (with a magnetic field) the switch changing
it changes from #30->#87A to #30->#87
that means you now have 12V+ on #87, (nothing on #87A) anymore. This way your headlight is fed with power causing it to light.
Now you probably think: why all that ????
you could always go:
lightswitch
"Battery plus" ----------------------/------------+
X (headlight)
"Battery minus" ----------------------------------+
this is exactly what the older Mustangs are doing. But it has a lot of problems.
a) you don't want heavy gauge wires under dash
b) you run through a million connectors (causing this dim headlight issue)
c) you can properly separate the switched circuit from the powered (working) circuit
this way your the headlight gets the power directly from the selonoid without haveing t0o bother through firewall, dash, etc ....
probably a cause for headlight switches to give up constantly
hope that helps ...
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650cfm Edelbrock carb (1806), Holley headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
