Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-01-2008, 02:36 PM   #1
flyingfool
Default autolite carb dismatle
so i started to inspect and disassemble my autolite 4100 and after i popped the top plate off, i see two brass floats (?) not exactly sure what they are... anyway, on the bottom of one, on bottom of carb theres this little valve thing. how do i get those floats out (pop them out of their holders? and what bout the little wires holding em in) and how do i get that valve lookin thing out aswell.
hell, while im at it, whats the best way to clean one of these things? soak in solvent then...?
__________________
flyingfool is offline   Reply With Quote
Old 05-01-2008, 07:34 PM   #2
flyingfool
Default RE: autolite carb dismatle
aw c'mon, NO ones removed floats before?? i did get the power valve off after some fidling and research...just didnt want to break things haha
__________________
Old 05-02-2008, 12:56 AM   #3
Stepman
Vehicle: 69 coupe
Don't know what too tell you here. can you post a pic of your issue here. These things are best done visually.....or by someone that knows what's going on...Every thing is easily disassembled so, I don't understand the issue.
Stepman is offline   Reply With Quote
Old 05-02-2008, 01:00 AM   #4
mySAVIOReigns
Not sure about the parts inside. To clean it, I soaked it in carburetor cleaner for a few hours. Also a little bit of scrubbing.
__________________
My Website
Yep, I got a blog...
1966 Coupe
200ci, 170ci head, Holley 5200, C4, all brand spankin new
mySAVIOReigns is offline   Reply With Quote
Old 05-02-2008, 04:11 AM   #5
REAVER117
Vehicle: 1969 Mustang Mach 1
To get the floats off you should just have to wedge a small flathead screwdriver between the wire and the post, there is a little groove that they sit in.
__________________
|1969 Mustang Mach 1|302|Edelbrock Performer RPM Intake|Edelbrock Performer 600CFM Carburetor|
Pending Upgrades: Mustang II IFS with Coilovers and 11" Disc Brakes, EFI 351C, T5 Conversion...Oh and Paint.
REAVER117 is offline   Reply With Quote
Old 05-03-2008, 03:05 PM   #6
flyingfool
so heres the pictures.
the wire on the left of the jet thing is what im trying not to break...
and, just kinda out of curiosity, what does this thing do? it looks like it has somthing to do with a little pipe running down into the primaries.
carbs are still kinda a mystery to me. obviously. haha
__________________
Old 05-03-2008, 05:17 PM   #7
Stepman
Vehicle: 69 coupe
Wow, that's a close up! never seen one like that but, I agree with the screwdiver. It should just snap off the pin. I would think the whole assembly would just lift out normally though.
The second pic is a bowl vent. Never seen one mounted sideways (verticle) though.
To clean, I usually get a gallon of carb cleaner. Comes with a basket to put the smaller parts in..let em soak for 30 min's to an hour and rinse with water, then blow dry. Nice to have compressor too, to blow out the small passages.
Old 05-03-2008, 06:15 PM   #8
Oxnard Montalvo
Oxnard Montalvo's Avatar
Vehicle: 1966 Mustang GT Fastback
The wire rides in a groove and should pop right off. Then the floats will come out and the needle valves will fall out. The needle valve seats unscrew but you need the proper tool or a WIDE flat screwdriver.
The thingy in the second picture is the hot idle compensator. It lets more "pure" air in when it's hot out, to keep the idle from becoming too rich.
Get a good kit and don't lose the secondary ball check. It's in the passage at the top of the secondary diaphragm cover.
__________________
Quote:
"Rectum? Damn near killed 'em"
Oxnard Montalvo is offline   Reply With Quote
Old 05-04-2008, 02:52 PM   #9
flyingfool
yeahh, pics are big, never got a chance to look at em before i posted haha. anyway, i tried the screwdriver thing, and it worked! so thanks!
when I took it apart, it looks like the diaphram in the back had been changed, and there was no ball in there[:@]ill have to call pony carbs to see if they have some around.
__________________
4100, autolite, blown, carb, carburetor, diaphragm, jet, power, secondary, tuning, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
