Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-21-2008, 02:40 PM   #1
68 Coupe
1968 Ford Mustang
My Garage
68 Coupe's Avatar
Vehicle: 1968 Coupe
Default Quarter skin replacement
Guys,
I have a question regarding replacement of my quarter panels skins. I pulled the last of the bondo off what I thought was the good side of the car (passenger) and found that the previous owner had put a quarter panel skin on and set it about 3/8" higher than it should have been. He partially filled the C scoop in with bondo on both the panel and door, and sanded on the bondo until he had formed his own contour lines. My question is; do the contour lines on the knock-off body panels match closely to the original body contours? If I buy a knock off quarter skin, will the C scoop lines match up with what is on the original car door as far as heighth and width? The doors and roof are the only exterior sheet metal that I am not replacing, and I want to make sure all of the aftermarket body parts will line up correctly.
Thanks
68 Coupe is offline   Reply With Quote
Old 10-21-2008, 02:53 PM   #2
rmodel65
2nd Amendment Gear Member
rmodel65's Avatar
Vehicle: 1965, ford, mustang fastback
Send a message via AIM to rmodel65 Send a message via MSN to rmodel65 Send a message via Yahoo to rmodel65
repop parts are decent quality, you can even spend a little extra to get ford stamping repops
__________________
Founder Rmodel's Mustang Militia
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
rmodel65 is offline   Reply With Quote
Old 10-21-2008, 04:22 PM   #3
Adrenolin
1967 Ford Mustang
Adrenolin's Avatar
Vehicle: 67 Ford Mustang
I used the repop ford stamped drivers quarter and it came out quite well. The biggest issue was the top contour in the C scope extended way too much into the door jam for some reason. The bottom contour was fine. I wound up having to cut a number of slices on the lip that folds into the door jam and carefully rework the panel. Took some time but it came out nicely and the door line matches evenly from top of the door to bottom now.
__________________
GT 351 - 67 Mustang / 68 Shelby Conversion (GT351.net)
Modified 351w, 4-Spd Toploader, Coil-Over Suspension, Power R&P, 4-Wheel Disks,
Currie 9" Rear with 3.25 & TrueTrac, Ron Francis Wiring, Vintage Air, Intermittent Wipers,
Sequential Tail Lights, Power Windows & Locks, Rear Window Defrost, Heated Seats....
Oct 2009 Mustang Forums ROTM Winner!
Adrenolin is offline   Reply With Quote
Old 10-21-2008, 05:58 PM   #4
cfd2bc
cfd2bc's Avatar
Vehicle: 1966
I used repop quarters, not Ford tooled, and they were really close to the original. I would imagine the Ford ones would be even better. I did have somewhat of the same issue with the top of the "c" scoop. In the end though the lines all matched up really well. This is a pic of it just tacked in place.
__________________
66 Coupe
289
Auto
Hooker Comp headers
Flowmaster dual exhaust
Crane RV cam
Edelbrock Performer 289
Edelbrock 600
http://www.youtube.com/watch?v=F8a_qFjq7ko
http://s418.photobucket.com/albums/p...20mustang%202/
http://s418.photobucket.com/albums/p.../66%20Mustang/
http://s418.photobucket.com/albums/p...20mustang%203/
cfd2bc is offline   Reply With Quote
Old 10-21-2008, 06:29 PM   #5
REAVER117
Vehicle: 1969 Mustang Mach 1
Does the repop quarter skin actually have a lip that goes into the door jam? I'm thinking of replacing one of my quarters which has a bit more bondo than I'd like.
__________________
|1969 Mustang Mach 1|302|Edelbrock Performer RPM Intake|Edelbrock Performer 600CFM Carburetor|
Pending Upgrades: Mustang II IFS with Coilovers and 11" Disc Brakes, EFI 351C, T5 Conversion...Oh and Paint.
REAVER117 is offline   Reply With Quote
Old 10-21-2008, 07:49 PM   #6
Adrenolin
1967 Ford Mustang
Adrenolin's Avatar
Yes, there is a lip that wraps around into the door jam... same as the original.
__________________
Old 10-22-2008, 12:00 AM   #7
68 Coupe
1968 Ford Mustang
My Garage
68 Coupe's Avatar
Vehicle: 1968 Coupe
cfd2bc,
Did you use a torch to remove the factory applied lead from the pillar/quarter panel joint? Will you use lead to fill it again, or a plastic filler? I am a little leery about doing a full quarter replacement because of that very joint
It does match up nicely though, so I believe I will be just fine keeping things lined up. Thanks for posting the picture!!!!!!
Old 10-22-2008, 12:04 AM   #8
68 Coupe
1968 Ford Mustang
My Garage
68 Coupe's Avatar
Vehicle: 1968 Coupe
adrenolin,
When you say the top C scoop contour extended into the door jamb, do you mean towards the door (ie no gap between door and quarter) or did it extend towards the car interior? I guess with a cutoff wheel and a welder I can make about anything fit eh?!
Old 10-22-2008, 12:14 AM   #9
fb72stang
fb72stang's Avatar
Vehicle: 1972 fastback
I have a similar problem. are the QP skins decent quality for a 71-73 fastback? I have removed the lead from the quarter seam and am wondering if a filler like Metal 2 metal will be able to hold up to the stresses of that seam. What do you guys think?
__________________
1972 mustang. Currently in a million pieces.
Originally came from the factory as a 1 of 1 car.
A/C, PDB
Rear Window defrost,
Black deluxe Mach one interior,
Power windows,
PS, 302 2V, FMX
Fold down, spoiler
Tilt wheel, etc.... I could go on all day...
Leave me some comments!
http://www.cardomain.com/ride/2910159
fb72stang is offline   Reply With Quote
Old 10-22-2008, 12:36 AM   #10
rmodel65
rmodel65's Avatar
yes metal to metal will be great for that job in fact it has greater corrosion resistance over traditional filler and is easier to use
__________________
~Samuel Adams
1967, bondo, door, fastback, ford, full, install, jam, mustang, quarter, quarters, replacement, replacing, skin, skins
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
