Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-21-2009, 05:13 PM   #11
69mach1377
1969 Ford Mustang
Quote:
Originally Posted by polo708 View Post
can you do a wider spacer (like a 1.5 or 2.0) on the rear to get that staggered look?
Sure, if you don't mind damaging your fenders and tires on large bumps...
__________________
69Mach1-SteetBoss377 Clevor,351W blk/stroker crank,10:1cr,351C-2V hds,2500 stall FMX,3.50:1 posi,rack&pinion/tilt,17x8 Mach1 Rims(2003),all MSD,Holley750,custom paint,Shelby drop,Cam Adv
http://photobucket.com/albums/v618/danaranda
69mach1377 is offline   Reply With Quote
Old 01-21-2009, 05:58 PM   #12
OEWheelsLance
Platinum Sponsor
OEWheelsLance's Avatar
Vehicle: Fitment for 1979 - Current on Mustangs
The offest on our wheel is 29.5mm.
Bullets with tires
__________________
TOLL FREE 866.273.3651
www.OEWheelsLLC.com
Email Lance
OEWheelsLance is offline   Reply With Quote
Old 01-21-2009, 08:59 PM   #13
plainsman1876
Why not just put 15" wheels they look better on the classic cars
__________________
Garland McNeil
plainsman1876 is offline   Reply With Quote
Old 01-21-2009, 09:50 PM   #14
polo708
1967 Ford Mustang
Vehicle: 67' coupe
Send a message via AIM to polo708
Quote:
Bullets with tires
is that the same offset as the stock bullitts?
__________________
-brian
67' Mustang coupe
347 stroker w/ AFR heads
polo708 is offline   Reply With Quote
Old 01-21-2009, 11:57 PM   #15
boogerschnot
1969 Ford Mustang
boogerschnot's Avatar
Vehicle: 69 Grande' Coupe
Location: Originally Iota, Louisiana in San Diego now..
Go with the 1.25" spacer in the rear and the 1.5 up front. I tried the 1.25 on the front of my car and it wouldnt clear the A arm, so I swapped with a 68 owner who had 1.5 spacers on the rear of his car. It tucked his wheel perfectly with the 1.25 and my front end now cleared the a arm with his 1.5..
As CPR streetmachines for a pic of his wife's car with the spacers and some 05 GT wheels..
__________________
69 Mustang Grande'
351W Holley 670
Edlebrock Performer Cam/Intake
Hooker Competition Headers
Dual Flowmaster 2.5" 40's with a H Pipe
FMX Auto / 9 Inch Rear w/2.75 Gears
http://www.cardomain.com/ride/2665602
boogerschnot is offline   Reply With Quote
Old 01-22-2009, 08:32 AM   #16
OEWheelsLance
Platinum Sponsor
I'm pretty sure that the stock 1994-2004 17x8 is 29.5mm, while the 2005 + is 45mm.
__________________
www.OEWheelsLLC.com
Email Lance
Old 01-22-2009, 09:00 AM   #17
Norm Peterson
2008 Ford Mustang
Norm Peterson's Avatar
Vehicle: 2008 GT Premium
Quote:
I agree wholeheartedly.
But the practical side of the matter is that there isn't much in the way of real performance 15" rubber available in adequate sizes any more. Virtually all of the good stuff is either too small in terms of load capacity, too narrow or too short, or is 17" and larger.
Anything less than 'H' speed rated does not feature a particular tire construction detail called a 'cap ply'. V-rated and higher get two cap plies, T-rated tires have 'cap strips', and S-rated tires have nothing. From an automotive engineering forum,
Quote:
I can see where a guy with a 4 door sedan might question the use of a V rated tires - and I tend to agree. However, I personally don't recommend anyone use lower than an H rated tire on anything! (unless it's unavailable in the size needed.)
The short explanation for this is:
Adding a cap ply to a tire seems to disproportionally improve the tire's resistance to tire failure. Pretty much all tire failures occur in S and T rated tires (H and higher are almost immune).
The boldface part has been my position from long before internet forums existed, without really knowing why it was a good "cutoff point" until rather recently.
Yeah, I guess I was ranting a bit . . .
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
Norm Peterson is offline   Reply With Quote
Old 01-22-2009, 09:09 AM   #18
Norm Peterson
2008 Ford Mustang
Don't know if the Cobra "R" wheels are supposed to be different then OE, but they're listed at 15 mm. Other 1994-2004 wheel offsets vary from 20 up to 30.
Source: 2009 FRPP catalog.
Norm
__________________
Old 01-23-2009, 12:44 PM   #19
rst08tierney
Keep it simple with ttII you cant go wrong
__________________
rst08tierney is offline   Reply With Quote
Old 01-23-2009, 12:45 PM   #20
rst08tierney
<a href="http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=108967254& albumID=1715441&imageID=28189667"><img src="http://hotlink.myspacecdn.com/images01/125/a197e49667c1a5a9c6da1e9e13469f5c/m.jpg" alt="" /></a>
__________________
05, 16, 1996, 2006, 65, adapter, classic, coupe, kit, mustang, rim, rims, spacer, v6, wheels
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
