I have aline on some heads that are describe as 1966 289 Hi-po heads. How can I tell if these are Hi-po heads and would they be off a K code motor.Also what would the value of these heads if they are what they say they are.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I have no idea of the value, but I do know that the difference is that there are machined pockets for the valve springs. The non performance heads have the spring setting on a machined area that is level with the surface. I suppose that these pockets were machined to allow for a little taller valve springs.
__________________
Have a Great Day,
Doc
ASE Master
hipo heads have screw in studs, but that's not a guarantee as that could have been modified. There's an easy way to tell though.
The double dot just above the 289 in the casting.
I'll see if I can find a picture ...
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back. http://www.gascc.ie
The machined valve spring pockets are an easy way to tell from a picture. But even if they are real, there's no reason to want them over a set of standard heads. They use the exact same port casting as non-hipo heads.
__________________
Tad H.
'67 Fastback
331 stroker
upps. yah. should have mentioned that. unless you need them for your K-code car with k-code engine, go for a set of aftermarket alum heads.
i guess they're worth money to a collector who _needs_ them
__________________
1964 1/2
I saw a pair last year at a swap meet that went for $600.00. They were in serious need of repair. Least of which was the fact that where the rocker studs mounted the heads were cracked.
And somebody bought them.....
__________________
FORD..Free Of Republicans and Democrats.
Nightmist Blue 1966 Coupe.
289 A code. Holley 600. Edelbrock dual-plane Intake. TRI-Y headers & Glass packs. C-4 B&M Shift Kit, Kevlar Bands. Billet Servo. PowerTraX Auto Locker. 1 1/8" front 1" rear ADCO sway bars. KYB Gas-Adjust Shocks. Export brace and M/C bar. CSRP KH Disc Brake Conversion. Torq Thrust D's w/ B.F.G TA Radials.
