Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-10-2009, 01:50 AM   #1
stangtjk
Vehicle: 1968 coupe
Default ABS and Traction Control for my 68
My 68 is using the complete drive train, and front and rear suspension from a Mark VIII and I'm planning on plumbing the brake and fuel lines when I get out of college for spring break in a month or so. I'm trying to decide to use the ABS unit or not. What are your guys thought on the subject. I've got all the wiring and stuff from the Mark so it really wont be any trouble to put it in the only extra work would be mounting the unit somewhere. Any opinions?
stangtjk is offline   Reply With Quote
Old 02-10-2009, 02:27 AM   #2
Starfury
I'm going to assume you mean a Mark VII, not a Mark VIII, because the latter uses a 4.6L mod motor, which is not an easy swap at all.
Also, how are you planning to run the front suspension from the Lincoln? Mark VII's run on the fox chassis and use a modified McPherson strut front end.
In any case, my opinion: big fat NO. It'd be a severe PITA, and probably wouldn't work properly anyway unless you used all of the Mark VII brakes, and even then it wouldn't work well because the car isn't going to have the same balance, weight, traction, steering geometry, spring rates, etc. ABS systems are very vehicle-specific. Lots of R&D goes into designing the system to work with one particular vehicle. Change one thing, nothing works right.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 02-10-2009, 05:13 AM   #3
andrewmp6
No he used a mark 8 for parts used the whole front suspension.I'm not a fan of abs its for women and people that can't drive to me.
andrewmp6 is offline   Reply With Quote
Old 02-10-2009, 12:38 PM   #4
Starfury
Well, even if, I still wouldn't recommend it.
ABS is a good thing on a street car in almost all circumstances. It pumps the pedal much faster than you could ever hope to, allowing you to brake quickly while still being able to steer the car. It doesn't decrease stopping distance, but being able to steer in a panick stop is a big deal.
But, like I said, it's not something you want to mess with trying to retrofit into a different vehicle. Way too much of a PITA, with uncertain results and not much benefit.
Stability management is a different thing altogether, and something that might actually be built into the Mk VIII. I hate stability management. That is for people who can't drive. It tends to force understeer which may help people who don't know how to handle a vehicle, but having the vehicle do the complete opposite of what you want/expect it to do is rather disconcerting.
__________________
Tad H.
'67 Fastback
331 stroker
Old 02-10-2009, 01:39 PM   #5
stangtjk
Vehicle: 1968 coupe
Like I said everything is already in place its just a matter of installing the ABS pump. And yes I meant Mark VIII and yes I used the front and rear suspension. Like I said in my first post its just a matter of mounting the ABS unit and running the brake lines. The Mark VIII has traction control but it uses the ABS to control it so its either both or neither. The traction control can be turned off with the push of a button.
Old 02-10-2009, 02:01 PM   #6
stangtjk
Vehicle: 1968 coupe
I figured since everything the same other than weight and wheel base everything would work as it should if it was hooked up. This is not going to be a drag car or track car just a fun daily driver. I think I'll hook it up and see what happens. If it doesn't work out its just a matter of unplugging it and running some new brake lines.
Old 02-10-2009, 04:45 PM   #7
Starfury
Fair enough
__________________
Tad H.
'67 Fastback
331 stroker
Old 02-10-2009, 04:54 PM   #8
cprstreetmachines
Hells yes. You're already there.
__________________
turbocharged 1967 349 stroker
1/8 mile 6.966 @ 99.704 Rich
1/8 mile 6.47@107.6 Dustin 1.43 best 60ft
cprstreetmachines is offline   Reply With Quote
Old 02-10-2009, 11:15 PM   #9
Kotobuki
2006 Ford Mustang
Vehicle: 2006 Ford Mustang GT
I certainly say go for it. You've got the rest of the car in there, why stop now?
Kotobuki is offline   Reply With Quote
Old 02-11-2009, 01:50 AM   #10
rmodel65
2nd Amendment Gear Member
rmodel65's Avatar
Vehicle: 1965, ford, mustang fastback
Send a message via AIM to rmodel65 Send a message via MSN to rmodel65 Send a message via Yahoo to rmodel65
Quote:
+1 that thing is can handle like its on rails with that IRS, and the block is alum too
__________________
Founder Rmodel's Mustang Militia
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
rmodel65 is offline   Reply With Quote
68, classic, control, drivetrain, fan, lincoln, mark, mcpherson, mustang, replace, steer, struts, traction, vii, viii
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
