Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-18-2009, 02:55 PM   #1
68dustin
1971 Oldsmobile Cutlass
My Garage
Vehicle: 68 stang,67coug,70cutty
Default thinking about doing a 8.8 swap to my 68
so where should i begin... Should i go with a early 90's 8.8 with the 4 lug and convert it over to 5 lug? Or should i look for a early 90's explorer 8.8? What are the differences? what should i look out for? problem areas? I really dont want to shorten the rear end at all. anybody done this? please chime in with personal experiences? thanks
68dustin is offline   Reply With Quote
Old 02-18-2009, 03:06 PM   #2
Starfury
The explorer 8.8 has an offset diff, iirc, and won't make an ideal conversion. It moves the diff off-center of the tunnel, changing driveshaft angles and moving the pinion snubber off the bump stop.
A fox body 8.8 makes a great conversion because it's the perfect width for your car and usually comes with a traction-loc diff. 5 lug axles/brakes can be had from some 80's rangers and aerostars, easy finds in a junkyard. The only tricky part is hacking off the coil spring mounts and getting leaf spring perches welded on with the proper pinion angle. Nothing too difficult, but the angle does need to be correct.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 02-18-2009, 04:02 PM   #3
69FB
Vehicle: 1969 Fastback
I think some of the Thunderbirds and Lincoln Mark series cars had 8.8 rearend in them with trac-locs as well...
69FB is offline   Reply With Quote
Old 02-18-2009, 04:06 PM   #4
68dustin
My Garage
thanks.. that was some of the answers i was looking for.... go with the mustang rear end.. then covert it to 5 lug... what is the ideal pinion angle..ive been reading 4 degrees?
Old 02-18-2009, 07:02 PM   #5
JERM_1967stang
i've always been told no less then three no more then 13. but dont quote me on it not positive. i know its no less then 3 cause vibration control is the reason for pinon angle.
__________________
Jerm
JERM_1967stang is offline   Reply With Quote
Old 02-18-2009, 09:12 PM   #6
drexelsteve
late 90's explorer 8.8. 31 spline axles not 28 like fox stangs, disc brakes, tracloc diff's, width IIRC within an inch of the 68 8", readily available with 3.73 or 4.10's. Flange mount, no more ubolts. Best bang for the buck no question. The offset diff is absolutely nothing to worry about, think about it... hitting a bump changes the "driveshaft angles" lol. I've swapped an explorer 8.8 into a ranger, a jeep wrangler, and my 68 stang. Haven't broken one yet.
drexelsteve is offline   Reply With Quote
Old 02-18-2009, 09:20 PM   #7
dcohen
Send a message via AIM to dcohen
why not get a 9 inch?
__________________
"Dream as if you'll live forever, live as if you'll die today"
James Dean
dcohen is offline   Reply With Quote
Old 02-18-2009, 09:27 PM   #8
68dustin
My Garage
Quote:
so im confused?? explorer or mustang...??? do you have any pics of your explorer swap... how much is the center offset? where drive shaft is??
I really dont want to do a nine inch because of cost and finding one is a little harder than a 8.8, the 8.8 are a dime a dozen.
Old 02-18-2009, 10:27 PM   #9
andrewmp6
The Thunderbirds and Lincoln Mark 8 had a 8.8 but they was irs from 89 up i believe.Been me id build a 9 inch and forget about it the 8.8 is ok but i rather have a 9 inch.
andrewmp6 is offline   Reply With Quote
Old 02-19-2009, 02:07 AM   #10
Starfury
Drexel, an offset diff is something to worry about, especially if you're putting down enough power to cause axle wrap or smack the pinion onto the bump stop. Ideally, you want the u-joint angles to be as close as you can get them to eachother, and as small as you can get them. Offsetting the pinion doesn't help this. And that inch difference in width is going to make a big difference in wheel choice.
Considering how plentiful fox body rear ends are (I got one for free), and how easy it is to convert them to 5-lug, I don't see how an Explorer conversion is superior in any way, shape, or form.
__________________
Tad H.
'67 Fastback
331 stroker
1968, 67, 88, axle, body, brakes, conversion, dimensions, disc, early, explorer, fox, irs, lincoln, mk, mustang, rear, swap, width
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
