Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-19-2005, 03:28 AM   #1
67_FASTBACK
Send a message via AIM to 67_FASTBACK
Default Can I put a 4 valve carburetor on my 67's 289 engine???
I want to put a 4 valve on my 1967 fastback's 289 v8. It has a 2v Carburetor on it. Is this the only one that will fit on my engine. I want to do this to get the extra hp out of my engine. If putting on a 4v carb is not an option, what else can i do to raise my hp? muffler? some kind of intake upgrade? help me plz.
thnx
67_FASTBACK is offline   Reply With Quote
Old 06-19-2005, 03:41 AM   #2
nualln
Send a message via AIM to nualln
Default RE: Can I put a 4 valve carburetor on my 67's 289 engine???
you need to get an intake manifold that will allow you to use a 4v carb.
If you want to raise HP, consider headers, mufflers, h or x-pipe.
The potential for a 289 engine is almost limitless, so keep looking around.
BTW, what are you intentions for the car? street...dragstrip? casual cruising and carshows? daily driver?
__________________
nualln is offline   Reply With Quote
Old 06-19-2005, 04:32 AM   #3
67_FASTBACK
Daily driver with the occasional street race. Some cruising also.
thnx for the advice man.
Old 06-19-2005, 04:51 AM   #4
nualln
I have a 67 with a edelbrock performer intake and a holley 4160 (4v, 600CFM).
It's my daily driver, and I ocassionally punch it just to remind myself how much power I have.
Before you go out and blow tons of money to beat the other guys with souped up civics, do yourself a favor and get a pertronix ignitor and the flamethrower coil. It replaces the points and adds a little horsepower, as well as the reliability of not having to deal with points corroding/trouble starting. It's about 60 bucks for the ignitor and 30 for the coil. I noticed a little better off-idle throttle after I installed it (i.e. better peeling out). http://www.pertronix.com/
You could also get yourself a K&N air filter. Those things are massive and have a 1 million mile warranty. Theyre pretty expensive, but you have no air flow restriction. K&N filter from summit
With Carburetors, bigger is not always better. You want about 600 CFM for your 289. Buying a 700, or 800 CFM will only flood your engine and create hesitation (not to mention terrible gas mileage).
When you upgrade to a new manifold, try getting a dual plane manifold. They allow even distribution of airflow into the cylinders. It's a little more expensive, but worth it.
__________________
Old 06-19-2005, 04:55 AM   #5
eZ
nualln--
im having a 302 built now, should be done mid next week...i went with the performer intake and a 700 carb...you think the 700 is too much?
__________________
eZ is offline   Reply With Quote
Old 06-19-2005, 05:00 AM   #6
nualln
Im not a carb guru, but that seems to be on the edge of too much. It will probably work though.
Are you building it, or are you having a mechanic build it?
__________________
Old 06-19-2005, 05:17 AM   #7
67_FASTBACK
Dumb question, how do mufflers affect engine performance and overall hp (technically)
Old 06-19-2005, 07:38 AM   #8
TBIAgent69
a 700cfm is probably going to be too much unless you have a pretty dang high performance engine. Not that I like to magazine race, but take a look at this month's mustang monthly, and mustang and fords magazines. There's an article about carb tuning (using a 351W though) and also an article about building a budget 302 block. If you do the calculations for a stock motor, (I can't remember the formula for it, but I have it in my room somewhere) you'll end up with a 450cfm carb being right for a motor that tachs out at 6k rpm's.
TBIAgent69 is offline   Reply With Quote
Old 06-20-2005, 04:36 AM   #9
eZ
im having a mechanic build my 302...dont have all the specs for the motor yet but i gave the mechnic 5 grand to play with...i thought i remember him saying a 700 cfm
__________________
Old 06-20-2005, 04:41 AM   #10
nualln
If your mechanic is reputable, then you're probably fine.
Man, 5 grand to throw at an engine... Better be awesome.
__________________
289, 67, blow, carb, carburetor, engine, engines, hesitation, intake, issues, make, mustang, put, v8, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
