Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-22-2009, 08:33 AM   #11
truplayr251
1965 Ford Mustang
Upgrading to the 66 style mounts will fix your problem. I ran into the same clearance issue you are having with my 65. Its a simple fix and it will take 2 hours at the longest to swap them out. in NDP they are part number 6028-9-1A. You will also need to buy the appropriate mounts to work with these brackets.
truplayr251 is offline   Reply With Quote
Old 04-22-2009, 08:35 AM   #12
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
Thanks for the advice, but I actually already have 66 style mounts and frame brackets. Thats why I can't believe they don't fit, well the driver side is actually what doesn't fit.
tx65coupe is offline   Reply With Quote
Old 04-22-2009, 01:56 PM   #13
Starfury
Ron Morris mounts are plenty strong. I believe M+ uses them in at least one of their race cars.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 04-22-2009, 02:52 PM   #14
Deviousfred
1965 Ford Mustang
My Garage
Deviousfred's Avatar
Vehicle: 65 Mustang Coupe
Hey Ty, you should just buy my Patriot Shorties. LOL I pretty much gave up on the Header/Clutch Cable issue and decided to go with hydraulic clutch set-up.
What part of Texas are you in?
__________________
Fred
65 Mustang Coupe
Blah Blah Blah
Charlene
Deviousfred is offline   Reply With Quote
Old 04-22-2009, 08:16 PM   #15
EZFEED
EZFEED's Avatar
Vehicle: 1967 Mustang convertible
Quote:
Originally Posted by tx65coupe View Post
EZFEED, Thanks for the offer. Man that could be really cool to have one off headers. I am located in central Texas, so its quite a ways away from you.
I'm sure I will be able to figure something out. I may end up trying the Hedmans that Fakesnakes suggested in the JBA Header thread, if that custom exhaust shop that makes headers can't do anything.
http://mustangforums.com/forum/class...ent-issue.html
Well that sucks you're so far away. I sure would't mind helping you out on this. Before you buy anything though, why dont you ask some local fab shops to see if they can make a set for you. There's nothing to it really and its not that much work. In stainless I can make a set for pretty much anything for about $200 in materials at the most. Given that I'm willing to bet that a custom set might cost you in the neighborhood of $300-$350 or so maybe try that first. Measure the differences in adjustment that you need then take the set you have now to them to use as a pattern and give them the changes you need built in. Doesn't hurt to ask, you may be missing out on a really good deal and then in stainless so you'll get the look that you first wanted.
__________________
1967 convt "under construction"
http://img.photobucket.com/albums/v4...0cancer/p1.jpg
1923 Model T Ford roadser "almost done!"
http://img.photobucket.com/albums/v4...Picture146.jpg
1969 M35A2
http://img.photobucket.com/albums/v4...s/EZM35A21.jpg
1976 PLDvK 53/59 (one of three in the U.S.)
http://img.photobucket.com/albums/v4...s/EZPLDVK1.jpg
"Collector of old machines, tractors, and all sorts of other crap"
EZFEED is offline   Reply With Quote
Old 04-22-2009, 08:29 PM   #16
htwheelz67
get a set of Dougs headers......they will fit perfect
__________________
67 vert, 408 stroker 205cc TW heads, CI cust hyd roller,Dougs 1 3/4 try y's, global west neg roll,lentech aod...etc etc etc
htwheelz67 is offline   Reply With Quote
Old 04-23-2009, 03:27 AM   #17
tx65coupe
tx65coupe's Avatar
I'm near Austin. What part number are the headers that you have? What setup are you planning on running instead?
Old 04-23-2009, 03:29 AM   #18
tx65coupe
tx65coupe's Avatar
Quote:
That would be cool if we lived closer. I would like to build a set of headers. I would probably learn a few things.
There is a shop in Austin that I was told will make custom headers. I may go that route if I can't get these to fit well. With all the options it is difficult to decide what to do.
Old 04-23-2009, 04:06 AM   #19
EZFEED
EZFEED's Avatar
Try a sheetmetal fabrication shop too. Austin has lots of machine shops and fabrication shops that service the oilfield. Your in a great place to find places like this. If they have a tubing bender, welding machine, a saw, and a vertical mill then they can make headers. Just tell them to replicate using the set you have already plus X changes. If those guys your talking about cant/wont do it for a reasonable price then shop around bro
__________________
1969 M35A2
65, headers, hipo, manifolds, shorty
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
