I have a 67 with a recently rebuilt 289 - near HiPo specs:
4 bbl Holley 650 Street Avenger carb
Ford HiPo highrise intake
Crane mechanical lifter cam
Decked and ported HiPo heads
Balanced and Blueprinted
Pertronix in the distributor and rev limiter unit
The story:
Car ran great until last summer, then battery boiled over - acid everywhere
so I cleaned out everything and car has been sitting for 9 months..
I replaced
>New Alternator with Chrome 60A unit
>Put on gold '67 HiPo look underdrive alternator pulley (and belts might be tigher now - too tight?)
>New starter solenoid
>New Flame-thrower epoxy coil
>New spark plug wires
>New optima battery
>New in-line gas filter
>Drained and refilled radiator
(also replaced cowl brace, montecarlo bar, and other non-engine items, etc.)
So today is the big start-up day with everything replaced...
Starter turns engine over strong
After several tries, it finally fires up ..seems to need heavier application of gas pedal
I run it for several minutes with my foot holding it between 1500 - 2000 rpms
Pump it up to 3000 rpms, sounds strong
...but as soon as my foot comes off, engine abrubtly dies - no idle at all
spray carb with choke cleaner, and retry - same result over and over
the engine used to idle smoothly, now it won't hold idle
Thoughts??? (help)
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I think you have dirt/varnish in the idle circuit. You can pull it apart and use the gumout and clean the orfices out and try it. I'm running a Cater Comp 625 and had the same prob. That little red tube sure does help in directing the gumout!
__________________
66"GT coupe
351W
T-5 Trans
3.89 9"
Ground up and just needs paint and the easy stuff.
That's a definite possibility. Try cleaning the carb first, make sure the fuel filter and pressure are good, check to make sure you have spark. Once the basics are out of the way if the problem persists then it can be tracked down.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
The fuel filter is new, how do I check the fuel pressure? If it roars at half-throttle, wouldn't that mean the spark is ok??
Use a fuel pressure gauge. And checking spark will depend on what ignition setup you have. If it's factory, check the manual.
__________________
