Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-07-2009, 05:35 PM   #1
dterry68
Vehicle: 1968 Ford Mustang
Default Help with stroker questions.
i'm thinking about doing a stroker motor for my mustang since i need a new motor so i was wondering what motor is best to do a stroker to for a daily driver and how much would it be?
dterry68 is offline   Reply With Quote
Old 06-07-2009, 05:51 PM   #2
Stangman70
Vehicle: 1968 and 1970 mustang coupes, 56 Willys jeep
IMO, which is based on very limited information, it really depends on the existing motor. There are a number of options for a 302, most of which are very cost effective. The same can be said of the 351w. If you are looking for a daily driver motor however, I would hold off on the stroker motor and be more oriented towards modifying your current engine. IE new heads, lifters, cams, etc. However, that is just me.
Stangman70 is offline   Reply With Quote
Old 06-07-2009, 09:20 PM   #3
knuckless
1968 Ford Mustang
Vehicle: 1968, 2005
302 stroked to a 331 would be your best choice for a stroker daily driver. its what im building. it can make just as much power as a 347 but is more durable because of the reduced stroke
__________________
1968 Mustang Coupe
289 Edelbrock 4 bbl
Dual Purple Hornies Exhaust
2005 Mustang Coupe
5 Speed V6
"Lifes a long road and we all stop for gas"
knuckless is offline   Reply With Quote
Old 06-07-2009, 11:06 PM   #4
KevinG
Vehicle: 1968 Mustang Coupe
Checkout www.fordstrokers.com. It has several options. Even if you want to build it yourself this site will give you something to go by.
KevinG is offline   Reply With Quote
Old 06-08-2009, 12:24 AM   #5
jagass
Vehicle: none
I need to know this too...
__________________
Music is my LIFE!!![img]http://******************/images/85690f81aadc1749175c187784afc9ee.gif[/img]
jagass is offline   Reply With Quote
Old 06-08-2009, 02:16 AM   #6
Waffles
Waffles's Avatar
Vehicle: 1970 Mustang Fastback
Location: Detroit; where the weak are killed and eaten.
Send a message via AIM to Waffles
buy a 460 and stroke it to like 512. i think that exists. totally practical.
__________________
Waffles is offline   Reply With Quote
Old 06-08-2009, 11:01 AM   #7
urban_cowboy
1969 Ford Mustang
urban_cowboy's Avatar
Vehicle: '69 Mustang Mach1
In a 68, have you considered just putting in a built 351W? Earlier models are more geared to short deck ford small blocks, but 67+ have much more options.
302
Bore 4.0
Stroke 3.0
331 (302 Stroker)
Bore 4.030
Stroke 3.25
351W
Bore 4.0
Stroke 3.5
383W (351W Stroker)
Bore 4.030
Stroke 3.75
Yes, the 351 is a taller deck block, but consider the regular 351 if you are considering a 302 stroker. If you want more, the 383 can be a very stout torque monster than can still spin to 7000.
__________________
"Yeah, were runnin a little bit hot tonight. I can barely see the road from the heat comin' off of it." Van Halen
urban_cowboy is offline   Reply With Quote
Old 06-08-2009, 03:04 PM   #8
Stangman70
I agree with urban on this one. The ford strokers site is very informational and I was able to learn a great deal about the performance of the stroker motor in comparison with a daily driver. Man that sounds like a shameless plug.
Old 06-10-2009, 01:00 AM   #9
dterry68
i'm thinking about going for a 331. What heads would go best with it? I wanna make some reasonable horsepower, how much can they make?
Old 06-10-2009, 01:39 AM   #10
valley firearms
valley firearms's Avatar
Vehicle: 1968
There are some great heads out there. I personally like my Trick Flows over the AFR 185's because my TFS heads are heli-coiled. The AFRs are not. Stick with an American made head. After you pick a head, then choose your pistons. Some piston manufacturers will make a piston for your type of specific head. For instance, I just ordered a Mahle piston and the number starts with TWF (trick flow/ twisted wedge). This piston was designed around my heads. I will still check valve to piston clearances as well and you should too.
__________________
http://www.cardomain.com/ride/2981459
Know guns, know peace, know safety. No guns, no peace, no safety.
valley firearms is offline   Reply With Quote
363ci, kit, stroker
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
