Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-08-2009, 02:47 PM   #11
BA Mustang
1967 Ford Mustang
BA Mustang's Avatar
Vehicle: 1967 Mustang Coupe
Send a message via AIM to BA Mustang Send a message via Yahoo to BA Mustang
Turning that in will put less fuel in and out is more fuel.
__________________
ROTM November!
Own a red mustang join this group: Red
Own an I6 mustang join this group: I6
BA Mustang is online now   Reply With Quote
Old 06-08-2009, 03:09 PM   #12
67mustangreg
67mustangreg's Avatar
Vehicle: '67 Mustang
By turning it, you mean righty tighty leftie loosie?
67mustangreg is offline   Reply With Quote
Old 06-08-2009, 03:49 PM   #13
BA Mustang
1967 Ford Mustang
BA Mustang's Avatar
Yes, tightening it puts less fuel in, and loosening it puts in more.
__________________
ROTM November!
Old 06-08-2009, 06:38 PM   #14
67mustangreg
Based on the performance I already posted about how too mcuh kills it and too little kills it....can any of you take a stabbing guess at if it needs more or less? The springy little screw seems to be out kinda far.
Old 06-08-2009, 09:22 PM   #15
BA Mustang
1967 Ford Mustang
BA Mustang's Avatar
What you could try.
1. screw it in all the way, but not tight.
2. turn out 1 turn
3. see if engine starts
If it does not start then turn out 1 more turn and try again. I do this until I keep the car running, then you know the number of turns out needed and can start the fine tuning.
__________________
ROTM November!
Old 06-08-2009, 10:28 PM   #16
Cogtx
Cogtx's Avatar
Vehicle: 1967
Quote:
Originally Posted by 67mustangreg View Post
My 1967 mustang has what i believe to be a carb problem. When I start it up, if I let off the gas..the engine dies. If i give it too much gas...the engine stops making any sound at all and only revives itself if I let off quickly. If I keep the gas down too much for too long, it just dies.
Almost everybody I've asked has said that's the carb and it needs a rebuild. How do I go about doing this? (I know the rebuild kits are cheap) This is my high school project, and I my dad doesnt know anything about cars. I want to get my mustang back on the road and will be posting in here a lot more. Thanks.
Just a thought...I have an inline 6 which used to run poorly. Bought a carb rebuild kit from autozone and installed it after cleaning. Still ran poorly secondary to fuel filter collecting rust/junk from an old gas tank. I replaced the gas tank, cleaned out the fuel lines, and replaced the fuel filter. Runs fine now. Do a search for the correct tuning of the idle screws and you should be golden...good luck!!! stay in touch..
__________________
Father and Son '67 Stang Project ongoin'
200ci I6 1v 3 spd
Cogtx is offline   Reply With Quote
Old 06-09-2009, 01:14 AM   #17
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
I agree crap in the tank etc will cause all kinda of grief. If the car sat for any extended period of time in its life or was parked outside alot, then the tank is probably junk. I had a new tank in mine about 15 years ago and then for the last 10 years the car was in the garage under a cover and the tank was drained. Well the inside of the tank looked like part of the Titanic, so I replaced it. Just an FYI there is a fuel filter inside the top of your fuel pump on the 200.
tx65coupe is offline   Reply With Quote
Old 06-09-2009, 02:28 AM   #18
67mustangreg
Yeah. I thought about the gas tank being the issue. But, I'm 90% sure it was already replaced in the early 90's. many parts and reciepts in the car had 1993 on them....
I put HEET and other chems down to try and make the gas better. itsnt changing out the tank a pretty big job?
also, i will try your idea BA mustang....thanks guys!
Old 06-09-2009, 07:36 AM   #19
boeing747arowair
Vehicle: 1966, Mustang
Send a message via AIM to boeing747arowair
after 1965 there is no fuel filter on the fuel pump. It was moved up to the carb. If i believe, that only showed up on 65's
__________________
'96 Mustang GT
O/R H Pipe
BBK CAI
Steeda UDP
Flowmaster Original 40's
'66 Mustang Sprint
200 CI
C4
boeing747arowair is offline   Reply With Quote
Old 06-09-2009, 11:35 AM   #20
tx65coupe
tx65coupe's Avatar
My tank was replaced in 94 and it was junk, so just because its not the original tank deosn't means its good. Remove the filler neck or the sending unit and look inside to see if its clean or all corroded.
1100, 1967, 200, 66, autolite, barrel, carb, carburetor, forum, kit, kits, mustang, rebuild, single, sprint
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
