Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-28-2009, 05:46 PM   #1
royalcrown
Vehicle: 1966 Mustang Fastback
Default Hesitation Problem Just Started
Hey everyone. All of a sudden my car seems to hesitate a bit under acceleration at lower rpm's. For instance after shifting into gear (when the rpm's are low) and i accelerate i can kind of feel and hear the car hesitate over and over as i give it gas until i get into higher rpm's. Once I'm in the higher rpm range, the hesitation stops. Another example is that when I'm on the highway in 3rd gear (my top gear) going 65 there's no hesitation when i'm on the gas, but if i slow down to 55 in the same gear (rpm's are now lower) i can feel the hesitation when i give it gas. Also, when i'm sitting at idle, the car appears to be rocking side to side a bit more than usual. that could be my imagination but i'm pretty sure it started at the same time as when the hesitation started. When I'm coasting the car runs just fine. The best explanation I can give for the "hesitation" i'm experiencing is it kinda makes you rock forward and back in your seat as you're accelerating. Anyone know what my problem might be? I'm a little worried to drive it right now...
royalcrown is offline   Reply With Quote
Old 06-28-2009, 05:57 PM   #2
Starfury
Sounds like lean hesitation/misfire. What kind of motor/carb do you have?
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 06-28-2009, 05:59 PM   #3
1965fastback
1965fastback's Avatar
Vehicle: 1965 Fastback
Or a out of adjustment acel. pump on the carb.
__________________
65 fastback, Jasper 200, Pony Carbs Rebuilt Autolite 1100, C4 trans "The Shell."
Click it: http://osage-creek.com/cgi-bin/p/awt...-log-furniture
1965fastback is offline   Reply With Quote
Old 06-28-2009, 06:02 PM   #4
royalcrown
Quote:
It's a 289 with the 2 barrel carb
Old 06-28-2009, 10:50 PM   #5
1965fastback
Or it could be a low float level.
__________________
Old 06-29-2009, 08:26 AM   #6
kalli
Vehicle: 1964, Ford, Mustang
noting to do with accell pump if it jumps at idle and low rpm cruise.
It's either running too lean, or too far advanced. maybe somethign stupid happended that the contact breaker plate got loose or the contact breaker came out of whack or it's with the carb.
That could be either float level or something blocked with dirt or a vacuum hose fell off or got broken.
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
Old 06-29-2009, 10:18 AM   #7
1965fastback
After I read what i wrote i realized that.
__________________
Old 06-29-2009, 09:53 PM   #8
Starfury
I agree with Kalli. Start by checking the timing, both static and dynamic. Report back with the results.
If the timing checks out, check float levels. If the float levels are ok, a carb rebuild is probably in order. Easy job on a 2100.
__________________
Tad H.
'67 Fastback
331 stroker
Old 07-30-2009, 10:13 AM   #9
gmac429
Vehicle: 2005 mustang gt
Hey royalcrown. My 2005 Gt was doing the exact same thing. The local Ford dealership could not find the problem. A guy on Edmunds.com was also having the same problem also. He had his local Ford dealship replace the Throttle Position Sensor(TPS) and it solve his problem thus far. I done the same thing. I took the car in to our local Ford dealership for them to replace the TPS and now the car runs 100% better. It feels like it has more power. So far the problem have not returned. It will cost approximately $100 to have that TPS replaced. Good Luck.
gmac429 is offline   Reply With Quote
Old 07-30-2009, 10:31 AM   #10
boogerschnot
1969 Ford Mustang
boogerschnot's Avatar
Vehicle: 69 Grande' Coupe
Location: Originally Iota, Louisiana in San Diego now..
Quote:
Thats good feedback, but this is the classic section. He probably doesnt have a fuel injected motor. Its most likely a carburator.
__________________
69 Mustang Grande'
351W Holley 670
Edlebrock Performer Cam/Intake
Hooker Competition Headers
Dual Flowmaster 2.5" 40's with a H Pipe
FMX Auto / 9 Inch Rear w/2.75 Gears
http://www.cardomain.com/ride/2665602
boogerschnot is offline   Reply With Quote
06, 2005, 2100, 50, acceleration, autolite, bullitt, carburated, drive, gt, hesitation, idle, mustang, rpm, shifting
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
