Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-03-2009, 11:33 AM   #41
BA Mustang
1967 Ford Mustang
BA Mustang's Avatar
Vehicle: 1967 Mustang Coupe
Send a message via AIM to BA Mustang Send a message via Yahoo to BA Mustang
Summit sells the Federal Mogul parts, so I don't think that kit is bad.
__________________
ROTM November!
Own a red mustang join this group: Red
Own an I6 mustang join this group: I6
BA Mustang is offline   Reply With Quote
Old 07-03-2009, 06:03 PM   #42
jimmy428
jimmy428's Avatar
i had this problem with my 351C. i'm rebuilding the motor now. very good chance to clean up the engine bay and add a few ponies.
__________________
4.10s are highway gears
jimmy428 is offline   Reply With Quote
Old 07-03-2009, 09:21 PM   #43
Gun Jam
1966 Ford Mustang
Gun Jam's Avatar
Send a message via ICQ to Gun Jam Send a message via AIM to Gun Jam Send a message via Yahoo to Gun Jam
So if I read that right that kit comes with bearings, pistons, rings, cam, oil pump and other stuff? All for 300?
Wow I didnt even think you could buy a cam and maybe 1/2 a bearing set for that price. Is this stuff that crappy or do other places way over charge OR is that about normal price?
Thanks
-Gun
__________________
Masters of Industrial Technology intelligence thats why I own guns made to drop elephants.
Gun Jam is offline   Reply With Quote
Old 07-03-2009, 10:56 PM   #44
BA Mustang
1967 Ford Mustang
BA Mustang's Avatar
You could probably check summit on the prices since they carry most of that stuff.
__________________
ROTM November!
Old 07-05-2009, 12:45 PM   #45
AlexZi
AlexZi's Avatar
Vehicle: 1967 Ford Mustang Coupe
So I havent started her since Thursday, and I felt guilty letting my car sit there that long with no action, so I figured Id give it a start and see if there was any difference. I started her up about 5 minutes ago, and the pressure went up to 40psi...stayed for about 5 seconds, then sank to 20psi, then stayed there for about 5 seconds, then shot back up to 40psi for a few seconds, then down to 10psi and slowly down to 0.
The reason I bring this up is because Im curious about these spikes in pressure. Why am I getting pressure at first? Why does it then lose pressure, and regain pressure, and lose it again?
Its strange to me, but if anyone could shed light on the way this stuff works, that would be cool.
__________________
AlexZi is offline   Reply With Quote
Old 07-05-2009, 05:05 PM   #46
stefke
Vehicle: 1970 coupe + 1966 coupe
After reading this, i would pull out the engine and give it good check-up. After all, it's your daily driver. You don't to breakdown on the highway, at least don't let the damage get worse.
I'm currently rebuilding an 5.0 HO out of an Lincoln mark 7 ,that's supposted to go in my 70'er project car. (mustang coupe) Allthough the engine ran like a spurring kitten, i decided to tear it up an check it out. (also to clean and paint it) This was the right thing to do, cause the bearing are bad, not completely, but they will not last for long. It needs new bearing and the crank needs to be grinded.
stefke is offline   Reply With Quote
Old 07-05-2009, 05:30 PM   #47
Oxnard Montalvo
Oxnard Montalvo's Avatar
Vehicle: 1966 Mustang GT Fastback
You could always find a boneyard 302 and drop it in. That way you can drive your car all summer and rebuild your motor as cash permits.
__________________
Quote:
"Rectum? Damn near killed 'em"
Oxnard Montalvo is offline   Reply With Quote
Old 07-05-2009, 10:24 PM   #48
1965fastback
1965fastback's Avatar
Vehicle: 1965 Fastback
Or find a give away I6 to put around with til the 289 is fixed.
__________________
65 fastback, Jasper 200, Pony Carbs Rebuilt Autolite 1100, C4 trans "The Shell."
Click it: http://osage-creek.com/cgi-bin/p/awt...-log-furniture
1965fastback is offline   Reply With Quote
Old 07-06-2009, 09:21 PM   #49
AlexZi
AlexZi's Avatar
Im embarrassed yet relieved to say that my problem is half way solved. What was the real problem you may ask? Low oil. When my car was hot, I would read oil on the dipstick cause of small amounts of oil being circulated through the pan and ****. But when the car was cold, I was reading no oil. I didnt know this because I kept checking the oil with a warm engine or the car running.( I dont really know the technical reason I was reading oil while hot, but not while cold, but thats what was happening). Added 3 quarts of cheap oil and my pressure is fine. Oil change coming soon.
Now the second part of the problem...where did this oil go? Well, Ive been having a leak around my distributor shaft for a while now. Im a dummy, so Ive been mopping it up, but never digging in to why or how it was leaking. Lazy, huh? The oil would leak somewhere around there (Possibly from the intake or distributor shaft, maybe a bad gasket) and pool up in the crevices around it. Over time I could see how this could add up to alot of leakage. Im going to clean up the area and find the leak, and fix it.
But shes back up and running, and its a little embarrassing that such a simple thing caused so much chaos in my life.
__________________
Old 07-07-2009, 11:14 AM   #50
1965fastback
Moral of the story, check oil when cool, LOL! But it's great to hear ur Pony isn't dead after all.
__________________
classic, low, mustang, oil, pressure
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
