New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-02-2009, 12:14 PM   #11
boogerschnot
1969 Ford Mustang
boogerschnot's Avatar
Vehicle: 69 Grande' Coupe
Location: Originally Iota, Louisiana in San Diego now..
Quote:
Originally Posted by htwheelz67 View Post
booger, the dyno test on the performer int/cam/carb is 230hp.....your a long way from 300hp, the performer cam drops off way faster in a 351w than in a 302.
Nuke, I'd go the bolt ons first, with intake,carb,headers, 2 1/2" exhaust, maybe hot ignition, if its a 4bbl engine you have to run 92 octane and get the ignition recurved, you are kinda screwed with the almost 11.1 compression but ignition curve can be adjusted.
Then when you want to yank the engine, add cam, heads (if no rebuild bigger chambers) to get compression down to 10.1. Otherwise if you want to do a cam change while in the car I would recommend a custom cam to work with what you have as far as the long block.
Oh well, I can pretend right?? I thought that the stock 351 was putting out 230 or so from the factory.. According to the desk top dyno, I think I was a little closer to 270hp at 4000rpm.. And aftermarket heads brought it up to about 330..
__________________
69 Mustang Grande'
351W Holley 670
Edlebrock Performer Cam/Intake
Hooker Competition Headers
Dual Flowmaster 2.5" 40's with a H Pipe
FMX Auto / 9 Inch Rear w/2.75 Gears
http://www.cardomain.com/ride/2665602
boogerschnot is offline   Reply With Quote
Old 07-02-2009, 05:49 PM   #12
groho
All the perf upgrades are going to cost you $$. there are allot of little changes that are cheap DIY's, that don't cost $200-300-$400. Pertronics ign and coil, then open the plug gap. Re-jet your carb, K&N air filter, advance the stock timing to 10-12 degrees, etc, etc. this are little inexpensive things that can be done up front before you dump big money on HP parts. But, if you got the $$, exhaust, re-jet carb, intake, cam, and last but not least, heads, in that order.
groho is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
