Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-01-2009, 04:38 PM   #11
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
Vehicle: 94 Ford Mustang GT
Haha I just looked under the car at the oil pan and realized I can change the oil without even lifting the car up. Awesome!
__________________
1965 Wimbledon White Mustang Inline-6 200
1994 Canary Yellow Mustang GT 5.0
PSN: GreatWalrus
Videos
Voted as best sig quote of 2008
Live in Washington and own a Mustang? Join this group!
Canary94GT is offline   Reply With Quote
Old 07-01-2009, 04:54 PM   #12
BA Mustang
1967 Ford Mustang
BA Mustang's Avatar
Vehicle: 1967 Mustang Coupe
Send a message via AIM to BA Mustang Send a message via Yahoo to BA Mustang
Yep, I loosen the bolt by going through the engine bay.
__________________
ROTM November!
Own a red mustang join this group: Red
Own an I6 mustang join this group: I6
BA Mustang is offline   Reply With Quote
Old 07-01-2009, 05:17 PM   #13
Starfury
Ideally, as has been mentioned, you should be running Valvoline VR-1, or something else with a high ZDDP content. ALL diesel oils have now been switched to the new CJ-4 standard, which means they have a low zinc content. The only other oils I'm aware of that have a high ZDDP content are Mobil 1 20W50, some Royal Purple, Redline, and Kendall oils, and pure race oils. You shouldn't run a race oil (like Valvoline's race-only oils) in your street car, however, as they don't have adequate anti-corrosion additives or detergents. They're meant to be run hard and then drained out after every race.
For a filter, I'd recommend the stock replacement Ford FL-1 or a Wix filter. Napa Gold and Carquest's high end filters are made by Wix. High performance filters like K&N and Mobil 1 are also a good choice, but they're overkill unless you run synthetic and use extended oil change intervals. Avoid cheaper brand filters. They really are cheap pieces of crap. Filters like Fram and STP use cardboard end caps that disintegrate, rubber instead of silicone/nitrile backflow valves (if any), bent thin-gauge sheet metal bypass springs instead of a good coil spring, and cheap spot welded center supports rather than a coiled tube.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 07-01-2009, 05:31 PM   #14
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
I'm going to go with the Mobil 1 10W30 Clean 5000. Is that good (in reference to the zinc)?
__________________
PSN: GreatWalrus
Videos
Old 07-01-2009, 07:00 PM   #15
1971mach1
1971mach1's Avatar
Vehicle: 1971 Mach1 351c Tremec TKO 5-speed- yea!
Quote:
The ONLY Mobil 1 that has enough ZDDP is 15W-50. (not 20W-50, not 10W-30). Check Mobil1's website, they give it to you in ZN/PH. You want at least 1200ppm (or it may say .12). As you will see
all the rest of the oils (with API-SM standard) are now 800ppm (or .08).
Conventional oil is no better, if it has API-SM on it-it's bad. You want Valvoline VR-1, any weight is ok. (not regular Valvoline though).
BA Mustang
I invite you to do a search on ZDDP, it has been discussed alot in a few threads on this site. It's scary how many others don't know about this, especially since it affects our old car engines in a very bad way. Heck, I didn't know until about 6-8 months ago and the API- SM standard has been out for about 4 years. Your father's old trusty oil is not the same anymore! (unless it's been in the barn for about 5 years)
1971mach1 is offline   Reply With Quote
Old 07-01-2009, 09:11 PM   #16
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
Ugh well I just bought Mobil 1 10W30 Clean 5000. Don't know what to do now.
Valvoline VR1 is like 6 bucks more a quart...
Edit: I think I'll just buy some ZDDPlus and save myself some money.
__________________
PSN: GreatWalrus
Videos
Old 07-01-2009, 11:15 PM   #17
BA Mustang
1967 Ford Mustang
BA Mustang's Avatar
Quote:
Originally Posted by 1971mach1 View Post
BA Mustang
Alright, I'll look around.
__________________
ROTM November!
Old 07-02-2009, 12:59 AM   #18
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
Man I don't think my car has had an oil change in at least five years, so hopefully that means I have not put any API-SM s*** in there. I can tell you it is pretty damn sludgy though.
Is there anything I can dump in there to break loose the oil before I drain it with the car cold?
__________________
PSN: GreatWalrus
Videos
Old 07-02-2009, 01:28 AM   #19
knuckless
1968 Ford Mustang
Vehicle: 1968, 2005
get your self some pure kerosine
drain about 1-2 quarts of the old oil and then put that much kerosine in, run the engine until it gets warm then shut it off and drain everything, the kerosine will act like a soap and get all the sludge and grime out by breaking it up
but remember...turn it off once it gets warm to running temp
__________________
1968 Mustang Coupe
289 Edelbrock 4 bbl
Dual Purple Hornies Exhaust
2005 Mustang Coupe
5 Speed V6
"Lifes a long road and we all stop for gas"
knuckless is offline   Reply With Quote
Old 07-02-2009, 01:49 AM   #20
Starfury
ZDDPlus is an acceptable alternative to VR-1. If you're going to run that, I'd just use Castrol GTX in the future.
__________________
Tad H.
'67 Fastback
331 stroker
05, 15w50, 1994, 50, 65, 94, break, change, gt, mobil, mustang, oil, quarts, rebuilt, schedule, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
