I have a 289 Windsor which I plan to improve but I'm unsure about a couple of things and would like some engine simulations done.
Could somebody please simulate my engine with both of the cams listed below using both a 525 (BG Road Demon) and 575 (BG Speed Demon) (4 simulations in total).
It would be appreciated if you could post up the 4 simulated power and torque curves for me. I am only really intereseted up to 4000rpm.
If you can suggest improvements to improve the power a torque curves below 4000 rpm it would also be appreciated.
Sorry to ask so much.
The details of my engine and the cams are as follows:
ENGINE:
Engine Size: 289
Bore: 4" Stroke: 2.87"
CAMSHAFT
COMP CAMS
GRIND NUMBER FS XE256H
HYDRAULIC
INT EXH
DUR @.050 212 218
MAX GROSS VALVE LIFT .477 .484
1. according to this thing with all details (headflow etc) and a specific cam from em my engine makes 400+ horses. desktop dyno is more realistic with 340ish
2. the cam selection (best fit) is selected on engine ci and compression and weight. nothing else.
so even if you change the heads etc it will change the predicted HP, but the cam will remain the same, even if you re-run it.
it doens't take into consideration any gearing and driveline either.
utter crap, but colorful ..
EDIT: MATT, i saw your private message, but i have no idea how lolng it was there. forum doesn't notify. sorry.
I'm in Dublin, but I can see if I get to it when home next week
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back. http://www.gascc.ie
I would go with the bigger cam, I havent looked at the specs but I bet the two cams have identical ramps, also with the 9.8 compression the slightly larger one will work better. as far as carbs if they are both annular booster versions go the 575 cfm.
I dont have desktop dyno but I could guesstimate about 250fwhp from that combo.
__________________
67 vert, 408 stroker 205cc TW heads, CI cust hyd roller,Dougs 1 3/4 try y's, global west neg roll,lentech aod...etc etc etc
just for the carb decision. desktop dyno will show very very little difference when i select carb to be 525 or 575
if the 525 flows enough it will be the better one for better throttle response.
For a carb decision since you go with BG, tell them what you have and they'll point you to the correct carb. They are official enemies of overcarbing, so they'll direct you to the proper one
Kalli
__________________
1964 1/2
Thanks for the replies. kalli it would be great if you could run it through for me. No worries on the PM the forum doesn't notify me for anything either.
By the way the carbs are both annular booster with vacuum secondaries. Specs can be found at:
as long as your engine is a female v8 and not a male version i can stimulate it :P
__________________
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
He saied simulate......rerere, vrooommm, vrooommm, bbaabbaa, ppaappaa, bbaabbaa. Thats with a mild cam. I can give you a more lumpy cam if you wish......
sorry, I'm no help to you guys with your fancy carb thingies...But I can entertain...
i know it was a joke
__________________
~Samuel Adams
