Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-11-2009, 01:41 PM   #11
Randys66gt
Randys66gt's Avatar
Vehicle: 1966 Ford Mustang GT Coupe
it's a 15/16"
__________________
66"GT coupe
351W
T-5 Trans
3.89 9"
Ground up and just needs paint and the easy stuff.
Randys66gt is offline   Reply With Quote
Old 08-11-2009, 01:44 PM   #12
Se4mus1
thanks, now i cant find the indicator on the timing chain cover. you said drivers side looking down above the balancer. how close to the balancer is it? It turned out what i thought was at tdc was not so the timing marks werent near the indicator.
Se4mus1 is offline   Reply With Quote
Old 08-11-2009, 01:58 PM   #13
TexasAxMan
Vehicle: 1966 Mustang Coupe
Some timing pointers are cast into the front cover, others are bolt on. You haven't mentioned what year your car (or engine) is but the early ones were cast. It's just a protrusion that is real close to the balancer at about the 1 or 2 o'clock position (looking from the front of the motor).
__________________
1966 Mustang Coupe
302 w/ T-5
TexasAxMan is offline   Reply With Quote
Old 08-11-2009, 02:16 PM   #14
kalli
Vehicle: 1964, Ford, Mustang
if you have a manual car you can always put it into gear (4th) and move the car forward/backward. this will turn the engine.
the pointer is usually very close to balancer. but depending on engine can be passenger or driver side. can't miss that thing usually. wouldn't get a finger between the pointer and balancer. otherwise would make for inaccurate reading
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
Old 08-12-2009, 02:18 PM   #15
Se4mus1
its an auto 289 with ac making it very dificult to get to the balancer. is it possible that i dont have one? The car is stock completely in the bay exept for an old electronic ignition system so i thought it would be on the timing cover bu i still cant find it. Does anyone have a picture or something i can look at?
Old 08-12-2009, 03:23 PM   #16
TexasAxMan
You definitely have a balancer, it is between the pulley and the front cover. As for a timing indicator, if it was a bolt on style, it's possible it was removed and not replaced.
Check with some of the Mustang vendors that have on-line catalogs with pictures and search for timing indicator or pointer. Then you'll at least know what it should look like.
But as I said before, if it is a '67 or older it should be cast in. To check this (with engine not running of course) stick your hand down just below the water pump on the drivers side, near the 1 o'clock position. If there is a ~3/8" around protrusion that sticks out 3/4" or so, that's the pointer.
Good luck and report back if you run into further problems.
__________________
1966 Mustang Coupe
302 w/ T-5
Old 08-12-2009, 03:38 PM   #17
Se4mus1
that came out wrong. I know where the balancer is and the marks on the balancer. What I cant find is the pointer, sory for the confusion. Ill try fishing around for it and see what i come up with. Ifound a picture in my shop manuel that ill try and match it up with, if its not there how would i set the timing
Old 08-13-2009, 03:15 PM   #18
Se4mus1
Well the pointer isnt there, so i dont know what the next step would be. The block is from early 65, before the cut off and the car is a 66. I was under the impression that the pointer was supposed to be casted on to the timing cover... However i did find a chalk mark on one of the belts hooked up to the crank shaft pully, could that be a make- shift indicator and another pointer is somewhere else? anyways would I just be able to align it to were tdc is supposed to be base off of the picture in my ford shop manuel? If not what would the next step be? Ill post a picture of where its supposed to be
Old 08-13-2009, 03:33 PM   #19
crunchyskippy
Its probably not the original timing cover.
I was watching one of the "Power Block" shows a few weeks ago, and they fabbed up a pointer from a piece of welding wire. They simply bent it around a bolt and then snugged it into the timing cover. Of course, you'll still need to identify TDC and then bend the wire so it points to the 0* timing mark on the balancer.
Hope that helps.
__________________
___ ___ ___ ___ ___
__________________
1967 Mustang Coupe 302 Automatic
crunchyskippy is offline   Reply With Quote
Old 08-13-2009, 05:16 PM   #20
TexasAxMan
Well, you need a pointer, but as a makeshift, you can get the engine to TDC on #1 and align the rotor with the #1 plug wire. That should get you started (may run like crap) and then tune by ear to obtain the fastest idle. Take it for a drive and listen for pinging, which would mean you have it advanced too far.
I'm betting the timing cover was changed to the newer style and a pointer was not added. You should still get one and mount it up. They're pretty cheap. The only other way is if someone sawed the cast in one off, but I can't think any reason why someone would do that.
__________________
1966 Mustang Coupe
302 w/ T-5
1966, 2005, 289, 302w, 351w, 40, 69, bolt, engine, ford, gun, indicator, mark, marks, mustang, svo, timing
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
