The marks are on the balancer, not the pulley. They are probably very faint, take some sandpaper and sand all the way around the balancer, you should be able to find the marks.
While I could tell you how to find TDC and all that, you need the marks to be able to properly tune your car.
and a timing light. dont bother doing anything until you have a timing light.. We can make marks on the damper wheel if need be but nothing gets done without the timing light in hand first.
-Gun
__________________
Masters of Industrial Technology intelligence thats why I own guns made to drop elephants.
Actually, you could put the engine at top dead center for #1 cylinder and then install the dizzy with the rotor pointed to the #1 pickup. That would get you close enough to start it, but fine tuning the timing would require a timing light, pointer, and mark on the balancer.
__________________
"Yeah, were runnin a little bit hot tonight. I can barely see the road from the heat comin' off of it." Van Halen
Im getting the timing gun soon, for right now i just want to get it started... where exactly is the balancer? is it the disc thats inbetween the pully and the block? If anyone has a picture that would help. thanks for the help
again, sand it and you should see the marks. the indicator is on the timing chain cover you should be able to view it looking down into the engine bay from the driver's side. its on the drivers side just above the damper wheel.
-Gun
__________________
FOUND EM!!!!!!!! they were on the bottom of the balancer passengers side looking UP at the engine bay. I guess my dad found it easier to jack the car up insted of taking off the air compressor. fricken genius. anyways now i have to hand crank it to tdc? which way does it work, lefty to retard, righty to advance?
