Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-22-2009, 11:58 PM   #11
Stepman
Vehicle: 69 coupe
Well...ok, but the oil drains are right at the front and rear edge of the head. If you blow out the head gasket on the front or rear cylinder, it will push the oil out as the gasses look for an exit. This would also explain the "no coolant in the cylinders". If the intake fails, it will either be sucked into a cylinder or it will just dribble down the front or back of the motor since there is no pressure there.
Stepman is offline   Reply With Quote
Old 08-23-2009, 01:19 AM   #12
JMD
JMD's Avatar
Vehicle: 55 Lincoln
Quote:
Originally Posted by Stepman View Post
Well... If you blow out the head gasket on the front or rear cylinder, it will push the oil out as the gasses look for an exit.
Well, yea, if a head gasket were to blow in the extreme front or rear next to to the oil drain back holes....
but, do you suppose a head gasket would EVER blow there? I don't think it would ever happen without catastrophic engine failure of a spectacular nature.
Weird stuff happens, that said, I guess it may be possible to loose massive amounts of oil through a blown head gasket on a SBF, I just can't think of how at the moment, but I am a dumb ass though.....
__________________
"In America it is YOUR RIGHT to be as STUPID as you wanna be!!
http://s245.photobucket.com/albums/g...CMS/39%20Ford/
http://s245.photobucket.com/albums/g.../66%20Mustang/
JMD is offline   Reply With Quote
Old 08-23-2009, 01:42 AM   #13
Stepman
Vehicle: 69 coupe
Damn...and I have been the dumb ass around here lately....so, I guess we're even.
Old 08-23-2009, 03:12 PM   #14
Flash70
Vehicle: 1970 Mustang FB
Send a message via MSN to Flash70
Is the oil coming from around the cylinder that sounds like it is not working?
Flash70 is offline   Reply With Quote
Old 08-23-2009, 09:03 PM   #15
JMD
JMD's Avatar
Vehicle: 55 Lincoln
Don't give it a second thought,,,,, I put my foot in my mouth on a daily basis...
I just did not want to see a person pulling their heads off to fix a simpler issue!
__________________
Old 08-24-2009, 09:54 AM   #16
RolandT3Speed
Vehicle: 1967 Coupe
Head gaskets installed backwards perhaps?
__________________
'67 289 3 Spd Coupe in 4,981 pieces.
RolandT3Speed is offline   Reply With Quote
351, 66, block, coming, cover, cracked, engine, gallies, gasket, head, leak, leaking, mustang, oil, repair, side, valve, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
