Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-31-2009, 03:28 AM   #1
MonsterBilly
1966 Ford Mustang
Vehicle: 66 coupe
Default I am picking up a 8.8 exploder rear end
tomorrow. I found one with 3.55 gears and a track loc from a 95 with 28k miles on it. I am going to cut it down to fit into my 66 coupe. I have been reading up on it and i think this is the way to go.
SO i will add to this thread as i work through it. The doner car has front end damage so i think it will be in great shape. I will check it for striaghtness before i start the work..
First picture post coming tomorrow.
Oh yeh, i am getting the rear end for $150. complete with rotors and calipers.
__________________
66 coupe, 289, T5, Stealth Intake, Holley 670 Street Avenger, Centerforce Clutch, Headman Headers, Pypes Exhaust, Lunati Cam
MonsterBilly is offline   Reply With Quote
Old 08-31-2009, 09:24 PM   #2
Scott H.
Scott H.'s Avatar
Any thoughts to welding on some 9" tube ends"? No more "C" clips to worry about, inner and out races on the bearing...
I wouldn't get too excited about checking straightness until you are ready to weld. Despite the myths, these are pretty stout rear ends.
I'm looking forward to your build thread.
Good luck,
__________________
Scott Heath
http://www.cardomain.com/ride/2400202
Nothing groovier than the sound of a Supercharged, EFI 5.0 in a classic 'stang
Scott H. is offline   Reply With Quote
Old 08-31-2009, 09:34 PM   #3
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Sine you have to do some modifications anyway to make it fit, definitely do something bout getting rid of the C-clips. An axle spit out the side because the C-clip failed can really trash a 1/4 panel.
hiboostwoody is offline   Reply With Quote
Old 08-31-2009, 09:42 PM   #4
robs
robs's Avatar
Vehicle: 06 GT Coupe
The disc brakes will hold in the broken axle. The exploder 8.8 is teh win for Jeep TJ / XJ swaps for this reason.
__________________
69 Mach I (Since 5/78) / 06 GT (Since 5/09) Boomtubes, sequential lights, Bama 91 Torque tune, Hurst billet shifter, J & M LCAs. Home brew lowering brackets next.
Life is better at WOT!!
robs is offline   Reply With Quote
Old 08-31-2009, 11:55 PM   #5
hiboostwoody
Default DUH!
Forgot all about the caliper and rotor holding in a broken axle.
Old 09-01-2009, 12:54 AM   #6
MonsterBilly
1966 Ford Mustang
Vehicle: 66 coupe
Not familiar with the c clips! I went to pick it up today and it wasnt pulled from the donor yet. The thing had hardly and damage to the front. It should be really straight.
__________________
Old 09-01-2009, 08:22 AM   #7
scootchu
Vehicle: 1966 Ford Mustang Coupe
Good luck and I know I will watch this one.
__________________
1966 Coupe with a 302
scootchu is offline   Reply With Quote
Old 09-05-2009, 12:24 AM   #8
MonsterBilly
1966 Ford Mustang
Vehicle: 66 coupe
So i cant take any time to work on this over the weekend i will get my start on tuesday. Im gonna hit the coast with the family.
i picked up my rear end on monday. IT WAS THE WRONG ONE. once i got it home i noticed that it did have 3.55s but it was an open diff. so i returned it today and got the correct one. Man it is different than the first one. the first one that i picked up was from a 2wd.
So the one that i picked up today actually has 3.73 gears. I wanted these initially but they didnt have one. ithey shipped it from socal. Anyway it is from a 2000 exploder with 41k on it. I cant wait. this one came complete. even has the e-brake cable.
__________________
Old 09-06-2009, 02:22 AM   #9
photocliff
1969 Ford Mustang
photocliff's Avatar
This will be a good thread to follow. Any Pics?
__________________
Go Baby Go
photocliff is offline   Reply With Quote
Old 09-12-2009, 04:00 PM   #10
MonsterBilly
1966 Ford Mustang
Vehicle: 66 coupe
So i unloaded the rear end from my pick up.
I did some measuring and noticed that the drivers side is 3" longer than the passenger side. I am wondering though if i am measureing correctly. I measured from the housing. Should i measure from the pinion shaft? that way i am measureing from the true center?
Anyways, i started cutting off all the existing bracketry and crap like that. I should have it all smoothed out today and ready to cut. I have been reading all over the web that you can really cut it with just about anything. including a sawz all. But i was wondering if anyone had any ideas as to which tool will give me the straightes cut.
I have a portable band saw that may work but holding it straight will be tough.
I will post some pics tonight.
__________________
1967, 88, early, end, gear, mustang, rear, rearend, t5
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
