Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-04-2009, 12:21 AM   #1
Rainierarms
Vehicle: 1965 Ford Mustang
Default New owner of 1965 I6 Stang with 289 Conversion
I recently purchased a 1965 Mustang that was originally an Inline 6 but the engine & trans has been replaced. My main concern is stopping. I have read a lot about the I6 drums not being strong enough. I was looking at the CSRP disc swap and adding MustangSteve's power boost. First, would that work? Secondly, I don't know what kit I need to buy; the I6 or V8. I'm assuming I need the I6 but I would like to get the V8 version so I can swap it out to a 5 Lug wheel. I don't think that's possible from what I've been reading about swapping out rear-ends for a V8 version. Can someone shed some light please?
BTW, steering feels tight and suspension feels nice. It came with rear air shocks as well.
Rainierarms is offline   Reply With Quote
Old 09-04-2009, 12:35 AM   #2
Tony R
Tony R's Avatar
Vehicle: 65 mustang 91 exploder 94 F150
welcome to the forum. How close are you to vancouver wa? I have an 8 in that I am wanting to get rid of that came out of my 65.
Tony R is offline   Reply With Quote
Old 09-04-2009, 01:24 AM   #3
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
Vehicle: 94 Ford Mustang GT
Just pointing this out for someone with more expertise to clarify: Isn't it bad to have rear air shocks on a stock Mustang?
__________________
1965 Wimbledon White Mustang Inline-6 200
1994 Canary Yellow Mustang GT 5.0
PSN: GreatWalrus
Videos
Voted as best sig quote of 2008
Live in Washington and own a Mustang? Join this group!
Canary94GT is offline   Reply With Quote
Old 09-04-2009, 06:44 AM   #4
LynnBob Mustang
LynnBob Mustang's Avatar
Vehicle: 1999 GT, 1965 coupe
Quote:
Right or wrong That's all we grew up on using when I was into Mustangs back in the mid '80's.
I always hated air shocks because they jacked the back end up too much.
Lynn
__________________
'99 GT automatic
CDC Shaker scoop, K&N Filter
MAC cat back
Max Speed 1 ˝” Lowering springs
KYB GR2 shocks and struts
Cobra front brakes
'65 Mustang coupe in progress
LynnBob Mustang is offline   Reply With Quote
Old 09-04-2009, 07:06 AM   #5
latamud
Swap in V8 spindles and at least an 8" rear end. The V8 steering components are stronger too.
__________________
66 Coupe, 408 Clevor, Viper T56, Cobra IRS
latamud is offline   Reply With Quote
Old 09-04-2009, 08:21 AM   #6
tx65coupe
tx65coupe's Avatar
Air shocks are a bad idea. They can punch holes throught the trunk.
tx65coupe is offline   Reply With Quote
Old 09-04-2009, 08:25 AM   #7
tx65coupe
tx65coupe's Avatar
If this were my car, I would find an 8 inch like Tony has and get Granada disc brakes up front. Then it would be 5 lug all around. The rear drums are fine. This would be a simple and inexpensive way to convert it and you would be using Ford parts.
I have Granada brakes on mine. This is a great upgrade.
There is nothing wrong with the other brake upgrades mentioned.
Old 09-04-2009, 06:44 PM   #8
JamesW
Moderator
1965 Ford Mustang
Welcome to the forum! You sound just about where I was 10 years ago when I bought my fastback. I had 4 lug drums on the front and someone had put in a 8" 5 lug rear out of a 67. (2" wider than a 65 and made the wheels stick out)
To answer your question, yes if you plan on keeping the car it would be wise to upgrade the brakes and steering to a V8 setup. You'll be buying new 5 lug wheels and there are a lot more choices than the 4 lugs.
Think about what types/size of wheels you want on your car. Stock 14s all the way up to 17's. This will have a factor in deciding on brakes. If you want to go with 17"ers, then there are several aftermarket brakes such as wilwood and baer, as well as the Cobra and S197 take off brake setup that MustangSteve sells. This is a good choice/good price if you're going that big. If you are wanting to stay smaller in wheels..say 15 or 16", then the Granada or CSRP setups are your best bargains. If you're wanting to go bone stock 14", the factory discs, or granada that have been modified to fit are your options.
Going with most of these require a spindle change, and the granadas have a different size tie rod. Now is the best time to change out the inner and outer tie rods, drag link and Idler arm.
__________________
If you're reading this, thank a Teacher.
If you're reading this in English, thank an American Soldier.
JamesW's Website
JamesW is offline   Reply With Quote
Old 09-05-2009, 01:55 AM   #9
Rainierarms
Thanks for all your input. How about adding power boost & discs up front and keeping the standard setup for the rear drum? Wouldn't the disc conversion fix the weak brakes?
Old 09-11-2009, 12:52 AM   #10
Rainierarms
Let me rephrase the question. Couldn't I swap to 4 Lug (I6 Version) Discs and add power boost? Wouldn't that provide enough stopping power on the V8?
1965, 1967, 200, 289, add, convert, converting, engine, i6, lug, mustang, power, sale, six, stick, straight, swap
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
