Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-07-2009, 06:39 PM   #11
2+2GT
Vehicle: 66 Mustang 2+2GT
Quote:
Originally Posted by my77stang View Post
i had a very mildly cammed 302 with the WORST heads possible on them (E6SE) and a crappy ford aluminum 4bbl intake from a early 80's GT (with tiny runners the about the size of a 255), along with factory exhaust manifolds,a Y pipe, and single exhaust......
took a holley 600 (factory carb from ford) off a 351w in a van that had just came into a local junkyard and bolted it on that 302. it ran PERFECT without having to adjust anything but the idle speed and the car would destroy the tires off the line. didn't smoke, didn't load up while idling in gear, no dead spots when accelerating, etc etc.
if thats not proof positive, i don't know what is.
With an upgrade cam, even a mild one, the 600 is probably the better choice.
Even crappy Ford iron heads can benefit a lot from some home port-matching on the exhaust side. Always a weakness of 289 and 302 heads.
That aluminum intake was the last version of the 60's iron 4V, not the greatest but it didn't totally suck, it was used on the 289HP. There was an early manifold that predated that, a repro is still available.
2+2GT is offline   Reply With Quote
Old 09-07-2009, 08:16 PM   #12
my77stang
my77stang's Avatar
Vehicle: 77 II, 06 GT
Send a message via AIM to my77stang Send a message via MSN to my77stang Send a message via Yahoo to my77stang
nope, thats not the same intake. the early 80's intakes ford used had a "waffle" looking pattern all over them and the intake runners were literally almost the size of a 255 intake port. here's a pic of 1 i found on fleabay just so you can see what im talking about.
the heads i had on that motor were not ported at all, and like i said they were the E6SE heads which had the heart shaped chambers and were literally the worst flowing heads ever bolted to a 302 from ford.
couple the above known facts with a stock single exhaust system and that carb still worked perfectly. the cam was a 218/228 .471/.471 summit grind and was the only thing done to the motor.
__________________
my77stang is offline   Reply With Quote
Old 09-07-2009, 08:26 PM   #13
2+2GT
True, it was not the same part, but it was the same design. Flip one of the photos and you'll see the runner design was virtually identical. I have seen these side by side, and it's pretty plain the manifold you have is the last version of the one I posted, which was the first. I agree, your heads are the pits. It'll take a lot of porting, at least on the exhaust side, to get them up to par. If you can do this yourself, it won't cost much, just the cost of a "valve job" gasket set.
The exhaust ports of the 289/302 head were always poor, and every time they changed the emissions setup they got worse. Odd, when you consider the 351W head was excellent, later on was adapted to the 5.0 HO and called the "GT40" head.
Crane used to sell "Fireball" heads, they would buy 289HP (later, 302) heads from Ford, and port the exhaust massively. You have to see the size of the hole to believe it:
Old 09-07-2009, 10:08 PM   #14
my77stang
my77stang's Avatar
runner design may have been the same, but the actual size of the ports were friggen TINY - much smaller than the heads themselves.
also, the motor i spoke of has long since been out of the car. im sporting a balanced 289 rotating assembly stuffed in a zero decked roller 5.0 block with 69 351w heads that have a whole lotta machine work done to them
__________________
Old 09-08-2009, 01:14 AM   #15
flyingfool
from the factory, ford was offering the autolite 4100s. 480cfm and 600csf (second number not positive about) so that right there is a reference. some people say that they cant actually perform to their rated cfm however
__________________
flyingfool is offline   Reply With Quote
40, 50, 72, carburated, carburator, carbureted, change, cylinder, e6se, ford, hard, head, information, instal, mach1, mustang, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
