I'm not a huge fan of full suspension kits. I can usually find something I don't like with each one, so I recommend buying parts piecemeal.
Ideally, unless you're made of money, you want to figure out what needs to be replaced before buying anything. For example, I've replaced just about every piece of my suspension aside from the LCA's, which are in good shape.
Like Ochohill said, poly strut rod bushings are a bad idea. Many people, including a few on this forum, have broken strut rods after installing poly bushings. The bushings don't don't flex enough, and when you combine that with 40yr old stress-weakened steel, you end up with an unsafe situation.
Here's what I run:
560lb 1" drop coils (from OpenTracker)
Roller spring perches (from Dazecars)
Stock replacement control arms (rubber bushings)
15/16" front sway bar
Shelby UCA drop
Mustangs Plus 4.5 leaf mid-eye (1" drop) spring kit
Edelbrock IAS shocks
Monte carlo bar
My car handles very well and still rides decently. Jonward now runs an almost identical setup and seems happy with it so far. If you're concerned about ride quality, I'd probably recommend KYB GR-2 shocks instead of the Edelbrocks, as well as GT front coils and GT 4-leaf rears.
The Shelby UCA drop should be considered mandatory if you're taking apart the front end, seeing as it's free and will provide the largest improvement in handling of any of the above mods without sacrificing ride quality. Likewise, an export brace should always be used, and a monte carlo bar is a good idea as well. The only reason I don't have an export brace installed is because the one I got was a Taiwanese pos and didn't fit.
Roller spring perches aren't exactly required, but they are nice to have if you can afford the extra expense. They improve suspension response, which improves handling, stability, and ride quality. 2+2GT doesn't think they're worth the money, but most of us who use them do
