Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-23-2009, 11:27 PM   #1
65California
65California's Avatar
Vehicle: 1965 Coupe
Default Gear shift linkage rattles loudly at high RPMs
Anyone know what's causing this loud rattle (sounds like an old fashioned phone ringing) at high RPMs? When you grab the shifter it stops.
I have a 6cyl manual 3speed and sounds like it's coming from the linkeage.
65California is offline   Reply With Quote
Old 09-24-2009, 03:06 AM   #2
Starfury
You need to rebuild the shifter. Cheap and easy to do. Pick up the 4sp (not 3sp) rebuild kit from Glazier's and use that for the rebuild. I did it on mine a few years ago and it made a world of difference.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 09-24-2009, 05:18 AM   #3
kalli
Vehicle: 1964, Ford, Mustang
i had the original 3spd as well. and for me it was the simple fact that the 2 bolts that hold the gear lever to the shifter (two bolts from top down) were loose.
It was hard to put into gear (find the gear) and the thing would rattle like mad.
It's easy to fix. just pull the rubber booot and you can access them.
If that's not it, do what Tad says
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
Old 09-24-2009, 05:25 PM   #4
Oxnard Montalvo
Oxnard Montalvo's Avatar
Vehicle: 1966 Mustang GT Fastback
Ring... Ring... Ring...
Are you sure it's not the phone?
__________________
Quote:
"Rectum? Damn near killed 'em"
Oxnard Montalvo is offline   Reply With Quote
2000, 2006, 5th, ford, gear, gears, linkage, loud, mustang, rattle, rattles, rattling, shift, shifter, shifting
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
