Quote:
Originally Posted by OCHOHILL
The idea of the aftermarket strut rods is to limit fore and aft movement of the lower control arm during braking/suspension movement.
But the original point is well taken. 65-66 LCAs do not pivot or adjust. If you dial anything but an ever so minor adjustment, it will bind the LCA. If you're just correcting the bad bushing situation, and are trying to limit the travel fore/aft, then adjustable arms are a good approach. If you're trying to make a front end alignment adjustment, they aren't a good idea.
