Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-28-2009, 10:14 AM   #1
RWP289
Vehicle: 1965 Ford Mustang
Default Rear Parking Brake cable routing at frame
I have an early 65 convert that has had the rear frame rails replaced. I am looking for info (pics, drawings, etc.) of how the parking brake cable are fouted from the backing plate to or through the frame rail and up to the tunnel. The frame rails in the car do not have hoels for the cables.
RWP289 is offline   Reply With Quote
Old 09-28-2009, 11:52 AM   #2
2+2GT
Vehicle: 66 Mustang 2+2GT
Quote:
64-65 cables are routed over the frame rail, not below as the later ones. The two crescents under the rear seat are for the cables.
2+2GT is offline   Reply With Quote
Old 09-28-2009, 01:36 PM   #3
RWP289
First, thanks for the quick reply.
Your answer resolves a riddle: It looks like the floor pan was also replaced (like a lot of early Mustangs) and with a pan that does not have the cresents. Is there a better solution than to drill the rear frame rails? If not, is there a place to get the measurements/dimensions of where the holes are drilled and how to support the cable at the back?
For example, these are from a 66 Mustang. Where do they mount?
Thanks again for your reply.
Randy
Old 09-28-2009, 01:59 PM   #4
2+2GT
I often see later cars with the 65 style floor.
Your easiest solution is to use the 66 cable, and go under the frame.
I don't have a 66 car handy to measure. Location is critical to allow adjustment and operation of the brake.
Old 09-28-2009, 03:10 PM   #5
RWP289
Wow!!
This is a great picture (as was your first one of the floor pan). And, I can actually infur a great deal from this photo about the correct placement. I spent 3 hours yesterday Goggling around looking for a picture like this one. Thanks.
Perhaps someone else may have a close-up of a 66 rear frame rail to show the verital placement (how high up the frame rail are the inside and outside hoes, I suspect the outside hole is higher than the inside one.)
Still, you have provided a great deal of help about the horizontal placement. I hope I can return the favor to you or someone else.
Thanks,
Randy
Old 09-28-2009, 07:10 PM   #6
2+2GT
There are no holes in the frame rail, the cable simply passes below the rail.
Old 09-28-2009, 09:53 PM   #7
RWP289
As I studied the photo you posted i saw that the cables simply passed below the rail. So when i got home, i looked at the chassis manual and it seems to show the cable going through the rail. So, i test fit everything and it clearly fits without doing that - just as your photos shows.
I am going to do it the same way as the photo.
Thanks,
Randy
06, 2001, 65, adjustment, brake, break, cable, emergency, gt, mustang, parking, rear, rear frame rail, rear parking brake, routing
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
