Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-29-2009, 12:43 PM   #21
crunchyskippy
I'm at a loss for the flat line at 2k (without stumbling). Most rev limiters that I've bumped up against still have some rpm fluctuation as it kills cylinder sparks.
Anyhow, here's a few more random thoughts:
[1] Back to basics again, verify your timing marks are consistent with cylinder #1 TDC.
[2] Try replacing the magnetic pickup/trigger in the duraspark distributor. Perhaps the trigger is "missing" at higher rpms and is simulating a rev limiter.
[3] Better yet, try swapping with a conventional points distributor/coil system to see if the problem remains.
[4] Try opening the throttle at the carb. Once the engine tops out at 2k rpm, press the accelerator pump manualloy to see if the engine speed increases. If it does, it would indicate fuel starvation. What carb are you running, btw?
__________________
___ ___ ___ ___ ___
__________________
1967 Mustang Coupe 302 Automatic
crunchyskippy is offline   Reply With Quote
Old 09-29-2009, 12:50 PM   #22
Gun Jam
1966 Ford Mustang
Gun Jam's Avatar
Send a message via ICQ to Gun Jam Send a message via AIM to Gun Jam Send a message via Yahoo to Gun Jam
I doubt its fuel related...I mean it worth checking...but fuel delivery just doesnt fit in this case...if it were that lean it would surge, pop, lean out and die at WOT....It wouldn't rev up nice and wouldn't rev down with out throwing a fit either.
I just cant picture how this thing can run great and not build rpm at WOT no load....
Dude I want video of this...I want you to get it to idle then grab the throttle linkage and pull it to WOT and hold it there while you record what happens... and record a slow gradual transition to wot as well as rapid..
-Gun
__________________
Masters of Industrial Technology intelligence thats why I own guns made to drop elephants.
Gun Jam is offline   Reply With Quote
Old 09-29-2009, 01:01 PM   #23
my77stang
my77stang's Avatar
Vehicle: 77 II, 06 GT
Send a message via AIM to my77stang Send a message via MSN to my77stang Send a message via Yahoo to my77stang
hey gun, fwiw vacuum advance dizzys still have mechanical advances in them as well
__________________
my77stang is offline   Reply With Quote
Old 09-29-2009, 01:04 PM   #24
Gun Jam
1966 Ford Mustang
Gun Jam's Avatar
all of them do or just this brand?
I got rid of my vac advance so long ago I dont remember what it looked like inside
__________________
Old 09-29-2009, 01:28 PM   #25
jcoby
Vehicle: 1967, Ford, Mustang
-Gun
yeah i know what you mean. a video would be a huge help here. a video with a vacuum gauge hooked up doubly so.
it's possible that the valves are all screwed up and it's getting enough fuel/air for idle but it runs out at 2500. I've never heard of an engine that runs "great" until 2500.
jcoby is offline   Reply With Quote
Old 09-29-2009, 01:48 PM   #26
Gun Jam
1966 Ford Mustang
Gun Jam's Avatar
The crazy thing is its no load...20% throttle should be enough to get it to rev dangerously high...
__________________
Old 09-29-2009, 03:48 PM   #27
my77stang
my77stang's Avatar
well... i know my accel rebuilt duraspark II dizzy has both - pretty sure they all do.
__________________
Old 09-29-2009, 05:06 PM   #28
kevink1955
Vehicle: 67 Ford Mustang
You said in a previous post that it sounded like it had a load on it like it was in drive.
You could have a trans problem and it may be using all that power in the torque convertor just like you were power brakeing it aganst the convertors stall speed.
Try this, you say it revs to around 2000 rpm, bring it up to about 1800 for a minute or 2 and see if the cooling lines to the trans get real hot. Also check the temp of the convertor if either are very hot you have a trans problem.
kevink1955 is offline   Reply With Quote
Old 09-29-2009, 05:11 PM   #29
Gun Jam
1966 Ford Mustang
Gun Jam's Avatar
Thats a great idea but wouldn't that cause the engine to die?
a 1500 TC powerbrake should cause the engine to stall / die at about 1500 rpm right?
-Gun
__________________
Old 09-29-2009, 08:31 PM   #30
kevink1955
Do you have a drive shaft in the car right now?? The reason I ask is that if the shift lever on the trans was hit and forced out of normal position it is possiable it is no longer indexed with the shift valve in the valve body.
What can then happen is the shift valve can be in drive or reverse but the park lever is in park. This would load the engine just like you had it in drive and held the car back with the brakes.
If you have a driveshaft in the car you can usualy feel the car move either foward or reverse when the engine is first started til the park pall catches it.
If it sounds like it's making power it's got to be going somewere
3000, 46, 50, 50l, duraspark, firing, ford, gt, mustang, order, pops, retard, rev, rpm, search, stumbles, timing, wont
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
