I'm not sure about spool valve hook up but, want to throw another thought out there. Put it in reverse and see if it will rev...if not, it sounds like a fried forward clutch that won't let go.
... excellent ... another thing to try ... thank you
(on the Ford Trans forum, someone just informed me that I have the shift valve engaged correctly)
Just to be sure ..... fried forward clutch = needs rebuild ?
Sorry I cannot help more, I thought we were on the right track with the manual shift valve. I know nothing about AOD's so I cannot comment on the foward clutch idea.
I think I would report your findings on the tranny forum and ask if the foward clutch could cause this and if it as a common problem in the AOD
Please post back when you find the problem so we can all learn something
If the clutch is fried, it will be trying to go forward in ALL positions. So, if you put it in reverse, it'll try going forwards and backwards at the same time(can't happen). Also, yes, you have to open it up to fix it.
Nail on the head .... Thank You Stepman !
.... yup, it tries to go forward in all gears ...
... looks like I'll be getting a new tranny for (early) Xmas !
