Location: Originally Iota, Louisiana in San Diego now..
Throttle linkage?
Does the throttle keep moving back and you get no more? or is that with it pulled all the way? Are your "butterflies" opening up? Crunchyskippy might be onto something.
10 inches is pretty low. I get about 19-20 at idle.
__________________
69 Mustang Grande'
351W Holley 670
Edlebrock Performer Cam/Intake
Hooker Competition Headers
Dual Flowmaster 2.5" 40's with a H Pipe
FMX Auto / 9 Inch Rear w/2.75 Gears
Yeah you need to take the air cleaner off and look down the carb with the engine off and move the throttle to wide open do you see the plates at the front of the carb open all the way so they are straight up an down?
What ignition system are you using? Did someone install a 2k rev limiter for run in purposes?
At 2k does it still run fine or is it popping or surging?
-Gun
__________________
Masters of Industrial Technology intelligence thats why I own guns made to drop elephants.
what happens at 2 grand? she just stuck there, no sputtering or misbehaving. that nearly sounds like a rev limiter.
---->at just over 1K rpm it has advanced to 34 BTDC (with ported vac advance re-connected)
disconnect vacuum advance, plug the hose so carb can't suck air through it and check again. 34 at 1000 is way too much if it's caused by mechanical advance
even with choke fully engaged the engine should rev all the way to sudden death when you floor it as the choke is usually pulled open a bit when flooring.
when you open the throttle fully you should see 0" vacuum, can you confirm that as well?
with the vacuum I'm not sure:
hefty cams have less vacuum, but the vacuum is usually in relation to throttle position, so I don't understand why your vacuum is higher at 1000 rpm than it is at 500
Kalli
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back. http://www.gascc.ie
my vac reading is also higher at greater rpm no load.
I get about 12 or 13 at 700 rpm but close to 20 at 2000 rpm
If im going 60 mph in 5th im getting about 15 but if I go up a hill and maintain 60 by applying power vac will drop off...the bigger the hill the more vac drops
-Gun
__________________
ah ya ... the load .... still would be interested to hear what actually happens at 2000rpm. is it a specific rpm it won't go past, is it sputtering, misfiriong ... ?
__________________
1964 1/2
